Radio Communications Logo
A
Anonymous Posted on May 04, 2013
108 where is the modulation pot on Navaho 30a
Mike Charette
Level 3:
Genius:
  • Maxon Master 1,847 Answers
  • Posted on Oct 05, 2018
Mike Charette
Maxon Master
Level 3:
Genius:
Answers
1847
Questions
Helped
490420
Points
2212
VR 8 to the right rear of the component side of the radio as it faces you.
2007 Pontiac Solstice convertible. The sound through speakers quit?
Fuse or Relay Number Fuse Rating Protected Component 1 40A Body control module - battery power in feed 1. 2 20A Power outlet main console bin. 3 40A Body control module - battery power in feed 2. 4 30A Fuel pump. 5 5A Powertrain control module keep alive power. 6 20A Powertrain control module power. 7 20A Canister vent solenoid. Evaporative leak control module. Exhaust gas heat recovery (hybrid electric vehicle). Tank pressure control valve (hybrid electric vehicle). Vapor blocking valve. Universal exhaust gas oxygen 11. Universal exhaust gas oxygen 21. Catalyst monitor sensor 12. Catalyst monitor sensor 22. Fuel flap door (hybrid electric vehicle). 8 20A Cooling fan relay coil. Battery interrupt box. Transmission oil pump. Auxiliary coolant pump. Engine coolant bypass valve. Electric A/C compressor (hybrid electric vehicle). Active grille shutters. 9 20A Ignition coils. 13 40A Front blower motor relay. 14 15A Transmission oil pump. A/C compressor variable clutch. Auxiliary pumps (hybrid electric vehicle). Electric A/C compressor (hybrid electric vehicle). Active grille shutters. 16 15A Windshield and rear window washer pump relay power. 17 5A Charge status indicator (hybrid electric vehicle). 18 30A Starter motor. 21 10A Headlamp red and blue flasher. 22 10A Electric power assisted steering module. 23 10A Anti-lock brake system module with integrated park brake. 24 10A Powertrain control module. Hybrid powertrain control module. 25 10A Air quality sensor. 360 camera with park aid. Rear view camera. Blind spot information system. Adaptive cruise control module. 26 15A Transmission control module. 28 40A Anti-lock brake system valves with integrated park brake. 29 60A Anti-lock brake system pump with integrated park brake. 30 30A Driver seat module. 31 30A Passenger seat motor. 32 20A Front media bin power point. 33 20A Rear cargo area power point. 34 20A Console end cap power point. 35 20A Console end cap power point. 36 40A Power inverter. 38 30A Climate controlled seat module. 41 30A Power liftgate module. 42 30A Trailer brake control module. 43 60A Body control module. 44 10A Brake on and off switch. 46 15A Battery charger control module (hybrid electric vehicle). 50 40A Heated backlite. 54 20A Visor control module. Run/start access feed. 55 20A Trailer tow park lamps. 57 30A Trailer tow battery charge. 58 10A Trailer tow backup lamps. 61 15A Not used (spare). 62 15A Headlamp washer pump. 64 40A Four-wheel drive module. 69 30A Front window wiper motor. 71 15A Rear window wiper motor. 72 20A Not used (spare). 73 30A Driver door module. 78 - Not used. 79 - Not used. 80 20A Not used (spare). 82 20A Not used (spare). 88 20A Rear blower motor. 91 20A Trailer tow lighting module. 95 15A Integrated spark control (hybrid electric vehicle). 96 15A Not used (spare). 97 10A Electric AC (hybrid electric vehicle). High voltage positive temperature coefficient heater (hybrid electric vehicle). 98 10A Traction battery coolant proportional valve (hybrid electric vehicle). 103 50A Rear power lug. 104 50A Rear power lug. 105 40A Not used (spare). 106 40A B+ feed. 107 40A B+ feed. 108 20A Spot lamp. 109 30A Passenger door module. 111 30A Body control module voltage quality monitor feed. 112 20A Not used (spare). 114 50A Not used (spare). 115 20A B+ feed. 116 5A Start access circuit. 118 20A Run/start feed. 120 15A Port fuel injectors. 124 5A Rain sensor. 125 5A USB smart charger 1. 127 20A B+ feed. Rear traffic advisor. Visor control module. 128 15A Not used (spare). 131 - Not used. 133 - Not used. 134 10A Delay accessory power. 136 20A Not used (spare). 139 5A USB smart charger 2. 142 5A Traffic cam. 146 15A Battery electronic control module. 148 30A Left-hand headlamp module. 149 30A Right-hand headlamp module. 150 40A B+ feed. 155 25A Transmission control module (hybrid electric vehicle). 159 15A DC/DC converter (hybrid electric vehicle). 160 10A B+ feed. Front warning lights. Strobes. 168 20A Low voltage service disconnect. 169 10A Coolant pump (hybrid electric vehicle). 170 10A Traction battery coolant pump (hybrid electric vehicle). Pedestrian sounder (hybrid electric vehicle). 177 10A Not used (spare).
Note: Spare fuse amperage may vary.
Passenger Compartment Fuse Panel
The fuse panel is under the instrument panel to the left of the steering column.
Note: It may be easier to access the fuse panel if you remove the finish trim piece.
Fuse or Relay Number Fuse Rating Protected Component 1 - Not used. 2 10A Moonroof. Inverter. Telematics control unit module. Driver door switch pack. 3 7.5A Memory seat switch. Wireless accessory charger module. Seat switches. 4 20A Not used (spare). 5 - Not used. 6 10A Not used. 7 10A Smart data link connector power. 8 5A Telematics control unit module. Hands-free liftgate actuation module. Power liftgate module. 9 5A Keypad switch. Rear climate control. 10 - Not used. 11 - Not used. 12 7.5A Climate control head. Gear shift module. 13 7.5A Steering column control module. Smart datalink connector. Instrument cluster. 14 15A Not used (spare). 15 15A SYNC. Integrated control panel. 16 - Not used. 17 7.5A Headlamp control module. 18 7.5A Steering wheel interface. 19 5A Headlamp switch. 20 5A Ignition switch. Telematics control unit module. Key inhibit solenoid lock. 21 5A Not used. 22 5A Not used (spare). 23 30A Not used (spare). 24 30A Moonroof. 25 20A Not used (spare). 26 30A Not used (spare). 27 30A Not used (spare). 28 30A Not used (spare). 29 15A Integrated computer screen. 30 5A Brake switch signal. 31 10A Terrain management switch. Selectable drive mode switch. Transceiver module. 32 20A Audio control module. 33 - Not used. 34 30A Run/start relay. 35 5A Low gear select. 36 15A Park assist module. Image processing module A. 37 20A Not used (spare). 38 30A Left-hand rear power window. Right-hand rear power window.
I need a fuse panel diagram for 2011 vw jetta tdi. My radio and rear defrost are not working.
Fuse panel C (dashboard)
Volkswagen Passat B7 - fuse box - dashboard Number Designation in Wiring Diagram Ampere rating [A] Function/component Terminal F1 Fuse 1 on fuse panel C -SC1- 7,5 Headlight DRLs, HID Adjuster motors, Whistler Radar Detector 15a F2 Fuse 2 on fuse panel C -SC2- 15 Airbag control module -J234-, Front passenger airbag -disabled- indicator lamp -K145- 15a F3 Fuse 3 on fuse panel C -SC3- 7,5 Light switch -E1- (T10h/4), Oil level thermal sensor -G266- (T6z/4), ABS control module -J104- (47/8), Instrument cluster control module -J285- (T32/31), Power steering control module -J500- (T6z/1) Data, Engine control module -J623- (T94/87), DSG transmission Mechatronic -J743- (T20e/13), Starter relay 1 -J906- (T7/1), Starter relay 2 -J907- (T9c/1) 15a F4 Fuse 4 on fuse panel C -SC4 7,5 Back-up lamp switch -F4-, High pressure sensor -G65-, Air quality sensor -G238-, Garage door opener control module -J530-, Parallel parking assistance control module -J791-, 16-pin connector -T16- (diagnostic connector), Automatic dimming interior rearview mirror -Y7 -, Left washer nozzle heater -Z20-, Right washer nozzle heater -Z21- 15a F5 Fuse 5 on fuse panel C -SC5- - Not used F6 Fuse 6 on fuse panel C -SC6- - Not used F7 Fuse 7 on fuse panel C -SC7- - Not used F8 Fuse 8 on fuse panel C -SC8- - Not used F9 - Fuse 9 on fuse panel C -SC9- - Not used F10 Fuse 10 on fuse panel C -SC10- - Not used F11 Fuse 11 on fuse panel C -SC11- - Not used F12 Fuse 12 on fuse panel C -SC12- 10 Light switch -E1- (T10h/8), Tiptronic switch -F189, Vehicle electrical system control module -J519- (T52c/1), Selector lever sensor system control module -J587, Electronic steering column lock control module -J764, 16-pin connector -T16- diagnostic connector (T16/16) 30a F13 Fuse 13 on fuse panel C -SC13- 10 Instrument cluster control module -J285- (T32/32) 30a F14 Fuse 4 on fuse panel C -SC14- - Not used F15 Fuse 15 on fuse panel C -SC15- 5 Electronic steering column lock control module -J764- 30a F16 Fuse 16 on fuse panel C -SC16- 5 Data bus on board diagnostic interface -J533- (T20/1) 30a F17 Fuse 17 on fuse panel C -SC17- 10 Steering column electronics control module -J527- (T16l/1) 30a F18 Fuse 18 on fuse panel C -SC18- - Not used F19 Fuse 19 on fuse panel C -SC19- - Not used F20 Fuse 20 on fuse panel C -SC20- - Not used F21 Fuse 21 on fuse panel C -SC21- - Not used F22 Fuse 22 on fuse panel C -SC22- 30 28-pin connector -T28a/22- (right A-pillar), 28-pin connector -T28a/22- (right B-pillar) 30a F23 Fuse 23 on fuse panel C -SC23- 30 Rear window defogger relay -J9-, Rear window defogger -Z1- 30a F24 Fuse 24 on fuse panel C -SC24- 20 Fuel pump relay -J17-, Fuel pump control module -J538- (T10n/1), Transfer fuel pump -G6- 30a F25 Fuse 25 on fuse panel C -SC25- 20 Climatronic control unit -J255- A/C control module -J301- Automatic transmission control module -J217- F26 Fuse 26 on fuse panel C -SC26- 15 Rear lid remote lock key switch -E232-, Compass magnetic field sensor -G197-, Rain/light recognition sensor -G397-, Remote start system relay -J471-, Analog clock -Y F27 Fuse 27 on fuse panel C -SC27 - Not used F28 Fuse 28 on fuse panel C -SC28- 30 Automatic transmission control module -J217- 15a F29 Fuse 29 on fuse panel C -SC29- 20 Vehicle electrical system control module -J519- (T52b/1) 30a F30 Fuse 30 on fuse panel C -SC30- 20 Vehicle electrical system control module -J519- (T52b/42) 30a F31 Fuse 31 on fuse panel C -SC31- 30 28-pin connector -T28/22- (left A-pillar), 28-pin connector -T28b/22- (left B-pillar) 30a F32 Fuse 32 on fuse panel C -SC32- 40 Trunk 12 V Plug [OEM-Fresh air blower control module -J126-], Fresh air blower -V2- 30a F33 Fuse 33 on fuse panel C -SC33- 30 Front seat heating control module -J774- (T8z/3, T8z/6) 30a F34 Fuse 34 on fuse panel C -SC34- 20 Power sunroof control module -J245-, (T16s/1) Sunroof motor -V1- 30a F35 Fuse 35 on fuse panel C -SC35- 30 Driver seat lumbar support adjustment switch -E176-, Front passenger seat lumbar support adjustment switch -E177-, Driver seat lumbar support curvature adjustment motor -V125-, Front passenger seat lumbar support curvature adjustment motor -V126- 30a F36 Fuse 36 on fuse panel C -SC36 - Not used F37 Fuse 37 on fuse panel C -SC37- - Not used F38 Fuse 38 on fuse panel C -SC38- - Not used F39 Fuse 39 on fuse panel C -SC39- - Not used F40 Fuse 40 on fuse panel C -SC40- 40 400W Inverter in Trunk [OEM- A/C control module -J301-], Fresh air blower -V2- 75a F41 Fuse 41 on fuse panel C -SC41- - Not used F42 Fuse 42 on fuse panel C -SC42- 30 Cigarette lighter -U1-12 V socket 2 -U18 75a F43 Fuse 43 on fuse panel C -SC43- - Not used F44 Fuse 44 on fuse panel C -SC44- - Not used Fuse 44 on fuse panel C -SC44- F45 Fuse 45 on fuse panel C -SC45- - Not used F46 Fuse 46 on fuse panel C -SC46- - Not used F47 - Fuse 47 on fuse panel C -SC47- - Not used F48 Fuse 48 on fuse panel C -SC48- - Not used F49 - Fuse 49 on fuse panel C -SC49- - Not used
Fuse panel E (VR6 only)
Panel E is the one in the trunk with your battery on the VR6.
Number Designation in Wiring Diagram Ampere rating [A] Function/Component Terminal F1 -Fuse panel B -SB1- - Not used F2 -Fuse 2 on fuse panel B -SB2- 15 -Engine control module -J623- 87a F3 -Fuse 3 on fuse panel B -SB3- 30 -Reducing agent reservoir sensor -G697- 2, Reducing agent reservoir processing unit, G698- 2 Coolant fan control module -J293-, Wastegate bypass regulator valve -N75-, Positive crankcase ventilation heating element -, N79-Reducing agent reversing valve -N473- 2 87a F4 -Fuse 4 on fuse panel B -SB4- 15 -NOx sensor -G295-2 Oxygen sensor 1 before catalytic converter -GX10-Oxygen sensor 2 before catalytic converter -GX11- 1 Oxygen sensor heater -Z19-Oxygen sensor 2 heater -Z28-1 NOx sensor control module 2 -J881- 2 87a F5 -Fuse 5 on fuse panel B -SB5- 5 -Mass air flow sensor -G70-2 Oxygen sensor 1 after catalytic converter -GX7-Oxygen sensor 2 after catalytic converter -GX8-1 Heater for oxygen sensor 1 after catalytic converter -Z29-Heater for oxygen sensor 2 after catalytic converter -Z30- 1 87a F6 -Fuse 6 on fuse panel B -SB6- 10 -EVAP canister purge regulator valve 1 -N80- 1 Secondary air injection solenoid valve - N112- 3 Camshaft adjustment valve 1 -N205-1 Fuel pressure regulator valve -N276- 1 Exhaust camshaft adjustment valve 1 -N318-1 Fuel pump relay -J17-3 Secondary air pump 87a F7 F7 -Fuse 7 on fuse panel B -SB7- 20 -Ignition coil 1 with power output stage -N70-Ignition coil 2 with power output stage - N127-Ignition coil 3 with power output stage -N291-Ignition coil 4 with power output stage -N292-Ignition coil 5 with power output stage -N323- 1 Ignition coil 6 with p 87a F8 F8 -Fuse 8 on fuse panel B -SB8- 10 -EVAP canister purge regulator valve 1 -N80- 1 Camshaft adjustment valve 1 -N205-1 Exhaust camshaft adjustment valve 1 -N318-1 Reducing agent heater control module - J891- 2 Leak detection pump -V144- 1 87a F9 F9 -Fuse 9 on fuse panel B -SB9- 5 -Brake lamp switch -F-Rear air distribution motor position sensor -G478- 87a F10 F10 -Fuse 10 on fuse panel B -SB10- 5 -Mass air flow sensor -G70-1 Fuel pump relay -J17-2 Automatic glow time control module -J179- 2 87a F11 F11 -Fuse 11 on fuse panel B -SB11- 30 DSG transmission Mechatronic -J743- 1 30a F12 F12 -Fuse 12 on fuse panel B -SB12- 15 Coolant pump -VX20- 1 87a F13 F13 -Fuse 13 on fuse panel B -SB13- 30 -Radio -R-Radio/navigation display unit control module -J503-External multimedia device interface -R215- 30a F14 F14 -Fuse 14 on fuse panel B -SB14- 5 -Motronic engine control module power supply relay -J271- 1, 3 Terminal 30 power supply relay -J317- 2 Engine control module -J623- 30a F15 F15 -Fuse 15 on fuse panel B -SB15- 20 -High tone horn -H2-Low tone horn -H7-Dual tone horn relay -J4- 30a F16 F16 -Fuse 16 on fuse panel B -SB16- 40 -Amplifier -R12- 30a F17 F17 -Fuse 17 on fuse panel B -SB17- 30 DSG transmission Mechatronic -J743- 2 30a F18 F18 -Fuse 18 on fuse panel B -SB18- 5 -Telephone transceiver -R36- 30a F19 F19 -Fuse 19 on fuse panel B -SB19- 5 Vehicle electrical system control module -J519- (T52a/24) 30 Ref. F20 F20 -Fuse 20 on fuse panel B -SB20- 40 Wiper motor change-over relay -J368-Wiper motor change-over relay 2 -J369- 30a F21 F21 -Fuse 21 on fuse panel B -SB21- 40 Secondary air injection pump motor -V101- 3 Auxiliary heater heating element -Z35- (T3hr/1) 2 30a F22 F22 -Fuse 22 on fuse panel B -SB22- 40 Auxiliary heater heating element -Z35- (T3hr/3) 2 30a F23 F23 -Fuse 23 on fuse panel B -SB23- 50 Fuse 32 on fuse panel C -SC32-Fuse 33 on fuse panel C -SC33-Fuse 34 on fuse panel C - SC34- 30a F24 F24 -Fuse 24 on fuse panel B -SB24- 50 Terminal 75 power supply relay 1 -J680-Fuse 40 on fuse panel C -SC40-Fuse 42 on fuse panel C -SC42- F25 F25 -Fuse 25 on fuse panel B -SB25- 40 Terminal 15 power supply relay 2 -J681- 30a F26 F26 -Fuse 26 on fuse panel B -SB26- 50 Automatic glow time control module -J179- (T11a/11) 30a F27 F27 -Fuse 27 on fuse panel B -SB27- 50 Coolant fan control module -J293- 30a F28 F28 -Fuse 28 on fuse panel B -SB28- 40 Vehicle electrical system control module -J519- (T52a/1) 30a F29 F29 -Fuse 29 on fuse panel B -SB29- 40 Vehicle electrical system control module -J519- (T52c/42) 30a F30 F30 -Fuse 30 on fuse panel B -SB30- 40 ABS control module -J104- (T47/1) 30a F31 F31 -Fuse 31 on fuse panel B -SB31- 30 ABS control module -J104- (T47/32) 30a F32 F32 -Fuse 32 on fuse panel B -SB32- 40 Auxiliary heater heating element -Z35- (T3hr/2) 2 30a 1) Only for vehicles with a 3.6L gasoline engine and engine code CDVB
2) Only for vehicles with a 2.0L diesel engine and engine code CKRA
3) Only for vehicles with a 2.5L gasoline enigne and engine code CBUA
WARNING: Terminal and harness assignments for individual connectors will vary depending on vehicle equipment level, model, and market.
Passat, Volkswagen electricity
1helpful
Fuse Box Diagrams (Inside and Engine) for 2009 Volkswagen Tigua?
Attached are the diagrams requested - good luck!
Fascia 1
Fuse, (Amps), Circuit
F1 -
F2 -
F3 -
F4 -
F5 -
F6 -
F7 -
F8 -
F9 (5A) Supplementary restraint system (SRS) control module
F10 (10A) Four wheel drive control module
F11 (5A) Parking aid control module, self-parking system control module
F12 (10A) Gas discharge headlamp control module (LH)
F13 (5A)
ABS/ESP system, AC system, anti-dazzle interior mirror, heated windscreen washer jets, seat occupation control
module, transmission control module (TCM), reversing lamps, engine management system
F14 (10A)
ABS control module, engine control module (ECM), heated seats, power steering control module, suspension
control module, trailer control module, AC control module, instrumentation control module, CAN data bus
gateway control module
F15 (10A)
Auxiliary heater, data link connector (DLC), parking brake control module, engine management, headlamp
direction control module
F16 (10A) Gas discharge headlamp control module (RH)
F17 (5A) Instrument panel
F18 (10A) Mobile telephone control module, multimedia control module
F19 (10A) Steering column function control module 2
F20 (5A) ABS control module, AC system, transmission control module (TCM)
F21 (15A) Door function control module, left rear, door function control module, right rear, multifunction control module 2
F22 (5A) Alarm system, multifunction control module 2
F23 (10A) ABS/ESP system, AC system, data link connector (DLC), rear view camera control module, headlamp switch
F24 (10A) Door function control module, driver, door function control module, passenger
F25 (20A) Transmission control module (TCM)
F26 -
F27 -
F28 (40A) AC control module, auxiliary heater
F29 (15A) Rear screen wiper motor
F30 -
F31 (20A) Auxiliary power sockets, cigarette lighter
F32 -
F33 -
F34 -
F35 -
F36 -
F37 -
F38 (10A) Steering column function control module 1
F39 (20A) Headlamp washers
F40 (15A) Trailer control module
F41 (15A) Trailer control module
F42 (20A) Trailer control module
F43 (25A) Sunroof control module
F44 (25A) Parking brake control module
F45 (25A) Heater blower motor, heated rear window
F46 (30A) Door function control module, driver, door function control module, passenger
F47 (30A) Door function control module, driver, door function control module, right rear
F48 (15A) Fuel pump (FP)
F49 (20A) multifunction control module 2
F50 (25A) Parking brake control module
F51 (40A) AC/heater blower motor control module
F52 (30A) Seat heater control module
F53
(20A/30A)
Headlamp washers
F54 (30A) Auxiliary power sockets
F55 (15A) Lumbar support adjustment
F56 (15A) Suspension control module
F57 (25A) Sun blind control module
F58 (1A) Trailer warning lamp
F59 (20A) Multimedia control module
F60 -
Fascia 3
in engine bay
Fuse (Amps) Circuit
F1 -
F2 -
F3 (5A) Multifunction control module 2
F4 (30A) ABS/ESP system
F5 -
F6 (5A) Instrumentation control module, steering column function control module 2
F7 (40A) Ignition main circuits
F8 (25A) In-car entertainment (ICE)
F8 (25A) Voltage converter
F9 (5A) Mobile telephone control module
F10 (5A/10A) Engine control module (ECM)
F11 (20A) Auxiliary heater control module
F12 (5A) CAN data bus gateway control module
F13 (15A/30A) Engine control module (ECM)
F14 (5A) Engine management system
F15 (5A/10A/15A) Fuel pump (FP), AC compressor clutch, engine management system
F16 (30A) Multifunction control module 2
F17 (15A) Alarm system horn
F18 (30A) Audio system
F19 (30A) Windscreen wiper motor
F20 (10A) Engine management system
F21 (10A/20A) Engine management system, fuel pump (FP) control module
F22 (5A) Clutch pedal position (CPP) switch
F23 (10A) Engine management system
F24 (10A) Engine coolant blower motor control module, engine management system, engine coolant heater
F25 (40A) ABS/ESP system
F26 (30A) Multifunction control module 2
F27 -
F28 (50A) Glow plug control module
F29 (50A) Electric seats
F30 (50A) Ignition switch circuits
Location Component
1 Petrol: Engine control (EC) relay 1
1 Diesel: Ignition main circuits relay
2 Petrol: Engine control (EC) relay 2
2 Diesel: Engine control (EC) relay
I need a fuse panal diagram for the 2013 VW Jetta, my 12 volt power ports are not functioning
Here you go. Fuses on E-box, on left in Engine Compartment
Fuse 1 - Not assigned
Fuse 2 - 10/15A - Engine control unit
Fuse 3 - 5A - Radiator fan control unit
Fuse 4 - 5/10/15A - Lambda probe heater,
Lambda probe 1 heater after
catalytic converter
Fuse 5 - 10A, 20A - Lambda probe heater1,
catalytic converter,
Fuel system diagnostic pump,
Charge pressure control solenoid
valve,
Exhaust gas recirculation cooler
change-over valve,
Crankcase breather heater element,
Vacuum pump for brakes
Fuse 6 - 5A, 10A,15A - Fuel system diagnostic pump,
Throttle valve module,
Activated charcoal filter system
solenoid valve 1,
Continued coolant circulation pump,
Auxiliary air heater heating element
Fuse 7 - 20A, 5A - Ignition transformer,
Fuel pressure regulating valve,
Fuel metering valve
Fuse 8 - 10A - Throttle valve module,
solenoid valve 1
Fuse 9 - 5A - Automatic glow period control unit,
Electric fuel pump 2 relay,
Fuel pump relay
Fuse 10 - 5A - Speedometer sender,
Brake light switch
Fuse 11 - Not assigned
Fuse 12 - 5A - Coolant circulation pump
Fuse 13 - 5A - Water pump
Fuse 14 - 5A - Engine control unit
Fuse 15 - 30A - Voltage stabiliser
Fuse 16 - 30A - ABS control unit
Fuse 17 - 30A - Automatic gearbox control unit
Fuse 18 - 20A - Automatic gearbox control unit
Fuse 19 - 1A - Onboard supply control unit
Fuse 20 - 30A - Onboard supply control unit (AW0)
Automatic intermittent wash and
wipe relay (AW1)
Fuse 21 - 50A - Secondary air pump motor
Fuse 22 - Not assigned
Fuse 23 - 40A - ABS control unit
Fuse 24 - 50A - Trailer detector control unit
Fuse 25 - 50A - Terminal 15 voltage supply relay 2
Fuse 26 - 60A - Automatic glow period control unit
Fuse 27 - 60A - Radiator fan
Fuse 28 - 40A - Onboard supply control unit (AW1)
Fuse 29 - 40A - Onboard supply control unit (AW1)
Fuse 30 - 50A - Terminal 75 voltage supply relay 1
Fuse 31 - 30A - Amplifier
Fuse 32 - Not assigned
Fuse assignment - Interior Fuse Panel
Fuse 1 - Not used
Fuse 2 - 5A - Electronic steering column lock control module
Fuse 3 - 10A - Instrument cluster control module
Fuse 4 - Not used
Fuse 5 - Not used
Fuse 6 - 10A - Vehicle electrical system control module,
Interior ceiling lights,
Tail lights
Fuse 7 - 5A - Fog lamp relay,
Instrument panel and switch illumination dimmer switch,
License plate lamps,
Fuse 8 - 7.5A - Windshield and headlamp washer pump switch,
Windshield washer pump
Fuse 9 - 5A - Airbag control module
Fuse 10 - 10A - Right steering column switch
Fuse 11 - Not used
Fuse 12 - Not used
Fuse 13 - 5A - Automatic dimming interior rearview mirror,
Light recognition sensor,
Air quality sensor,
High pressure sensor,
Climatronic control unit,
Tire pressure monitoring button,
Back-up lamp switch,
Left washer nozzle heater,
Right washer nozzle heater,
28-pin connector
Fuse 14 4- 10A - Left steering column switch,
ABS control module,
Light switch,
Airbag spiral spring/return spring with slip ring,
Fuel pump control module,
Fuse 15 - 10A - 16-pin connector (diagnostic connector),
Headlamp range control adjuster,
Auxiliary heater operation relay,
Mass airflow sensor,
Positive crankcase ventilation heating element,
Left front headlamp,
Left headlamp beam adjustment motor,
Right front headlamp,
Right headlamp beam adjustment motor,
Fuse 16 - 10A - Engine control module
Fuse 17 - Not used
Fuse 18 - 15A - Left front headlamp
Fuse 19 - 15A - Right front headlamp
Fuse 20 - 10A - Automatic transmission control module,
Selector lever sensor system control module,
Tiptronic switch,
Ignition/starter switch
Fuse 21 - Not used
Fuse 22 - 10A - Ignition/starter switch,
Converter box,
Alarm horn,
Interior monitoring sensor,
Alarm horn relay,
Fuse 23 - 10A - Vehicle electrical system control module,
Light switch,
Rain/light recognition sensor,
Compass magnetic field sensor,
Fuse 24 - 10A - Vehicle electrical system control module,
Access/start authorization control module
Fuse 25 - 15A - Automatic transmission control module,
Multifunction transmission range switch
Fuse 26 - 15A - Brake system vacuum pump
Fuse 27 - Not used
Fuse 28 - 40A - Auxiliary heater operation relay
Fuse 29 - 1A - Vehicle electrical system control module,
Fuse 30 - 20A - Cigarette lighter,
12 V socket,
12 V socket 2,
Blocking diode
Fuse 31 - 30A - Light switch
Fuse 32 - 20A - Light switch
Fuse 33 - 40A - Heater/heat output switch,
Fresh air blower relay,
A/C control module,
Fresh air blower switch
Fuse 34 - 15A - Left front headlamp,
Fuse 35 - 10A - Steering column electronics control module,
Instrument cluster control module,
Signal horn activation,
Fuse 36 - 25A - Vehicle electrical system control module
Fuse 37 - 15A - Left front headlamp DRL
Fuse 38 - 15A - Right front headlamp DRL
Fuse 39 - 15A - Low beam relay
Fuse 40 - 15A - Towing recognition control module
Fuse 41 - 15A - Towing recognition control module
Fuse 42 - 20A - Towing recognition control module
Fuse 43 - 30A - Front passenger door control module
Fuse 44 - A25 - Rear window defogger relay,
Fuse 45 - 30A - Driver door control module,
Fuse 46 - 30A - Left rear door control module,
Right rear door control module
Fuse 47 - 15A - Fuel pump control module,
Fuel pump relay,
Fuel primer relay
Fuse 48 - 20A - Vehicle electrical system control module,
Fuse 49 - 20A - Climatronic control unit,
A/C control module
Fuse 50 - 30A - Front seat heating control module
Fuse 51 - 30A - Power sunroof control module
Fuse 52 - 20A - Dual tone horn relay
Fuse 53 - 15A - Front seat heating control module
Fuse 54 - 15A - Fog lamp relay
Fuse 55 - 20A - Light switch,
Fuse 56 - Not used
Fuse 57 - 15A - Radio,
Fuse 58 - 1A, 30A - Telephone transceiver
DC/AC converter with socket, 12V-230V
Fuse 59 - 30A - Amplifier
Fuse 60 - 30A - Auxiliary heater control module
Fuse for the alarm system
Here is the full list of fuses for you! and for the car.
catalytic converter
valve,
change-over valve,
solenoid valve 1,
Fuel metering valve
solenoid valve 1
Fuel pump relay
Brake light switch
wipe relay (AW1)
Fuse 1 - Not used
Fuse 4 - Not used
Fuse 5 - Not used
Tail lights
Fuse 11 - Not used
Fuse 12 - Not used
Air quality sensor,
28-pin connector
ABS control module,
Light switch,
Fuse 17 - Not used
Tiptronic switch,
Fuse 21 - Not used
Converter box,
Alarm horn,
Alarm horn relay,
Light switch,
Fuse 27 - Not used
12 V socket,
12 V socket 2,
Blocking diode
A/C control module,
Fuel pump relay,
Fuel primer relay
A/C control module
Fuse 56 - Not used
Hope this helps
--N
Realistic navaho trc 30a
page 6 of service manual,you have to adjust L
L905,L906,L907,L908,L909,L910,L912,and L913
www.cbtricks.com for manual
Were are the relay or for passenger side seat electrical control buttons
There are a few different fuses and relays related to the passenger seat/ The below are the relating and attached is a picture of the fuse locations
108 30A** Passenger seat motor switch
118 30A** Driver and passenger climate
control seat module
Good luck
3helpful
2000 ford explorer, fuse box don't show me what fuses are for
There are two fuse boxes. A baqttery junction box under the hood on the drivers side and one inside on drivers side. Good luck.
Fuse/Relay
Location
Fuse Amp
Rating
Power Distribution Box
Description
1 60A** I/P Fuse Panel
2 40A** Blower Motor Relay
3 50A** 4 Wheel Anti-Lock Brake System
(4WABS) Module
4 30A** Power Windows, Power Moon
Roof, Power Seat
5 50A** Ignition Switch, Starter Relay
6 20A** Transfer Case Relay
7 - Not Used
8 20A** Air Suspension
9 40A** Air Suspension
10 30A** PCM Power Relay
1 10A* A/C Relay
2 30A* Heated Seats
3 30A* Heated Backlight
4 15A* Fog Lamps and Daytime Running
Lamps
5 4 3 2 1
10 9 8 7 6
12 11 10 9
8 7 6 5
4 3 2 1
15 14 13
2 1 1
9
6
10
8
7
5
175
MEGAFUSE
Roadside emergencies
197
Fuse/Relay
Location
Fuse Amp
Rating
Description
5 - Not Used
6 10A* Powertrain Control Module
7 30A* 4 Wheel Anti-Lock System
(4WABS) Module
8 15A* Rear Wiper Motor
9 20A* Fuel Pump Relay and RAP
Module
10 15A* Horn Relay
11 15A* Parklamps Relay and Mainlight
Switch
12 30A* Mainlight Switch and
Multifunction Switch
13 15A* Heated Oxygen Sensor, EGR
Vacuum Regulator, EVR Solenoid,
Camshaft Position (CMP) Sensor,
Canister Vent Solenoid
14 30A* Generator/Voltage Regulator
15 - Not Used
1 - Wiper Park Relay
2 - A/C Relay
3 - Wiper High/Low Relay
4 - PCM Power Relay
5 - Fuel Pump Relay
6 - Starter Relay
7 - Horn Relay
8 - Rear Wipe Down Relay
9 - Blower Motor Relay
10 - Rear Wipe Up Relay
1 - Not Used
1 - DRL Diode
2 - Electronic Engine Controls Diode
8helpful
3answers
I need a fuse number and location or a fuse box diagram for the brake lights on a 2002 E350 super duty
go to the link bleow and follow it to the Ford web site, there you can download a free owners manual, all fuse box info u need is in the manual.
http://www.edmunds.com/ownership/howto/articles/120189/article.html
7helpful
2answers
Diagram of fuse panel under dashboard
2003 Excusion, V10, 2wd, Eddie Bauer
I had a hardtimefinding this informaton, hope it helps.
fuses
Fuse link
cartridge
2A Grey Grey — — —
3A Violet Violet — — —
4A Pink Pink — — —
5A Tan Tan — — —
7.5A Brown Brown — — —
10A Red Red — — —
15A Blue Blue — — —
20A Yellow Yellow Yellow Blue Blue
25A Natural Natural — — —
30A Green Green Green Pink Pink
40A — — Orange Green Green
50A — — Red Red Red
60A — — Blue — Yellow
70A — — Tan — Brown
80A — — Natural — Black
Passenger compartment fuse panel / power distribution box
The fuse panel is located below and to the left of the steering wheel by
the brake pedal. Remove the panel cover to access the fuses.
Roadside Emergencies
To remove the fuse panel cover,
turn the panel fasteners
counterclockwise.
To remove a fuse use the fuse puller
tool provided on the fuse panel
cover.
The fuses are coded as follows.
Fuse/Relay
Location
Fuse Amp
Rating
Description
1 15A* Adjustable pedals
2 20A* Power point -floor console
3 20A* Power point – 3rd row
4 20A* Power point -instrument panel
20A* Power point -right rear quarter
6 20A* Trailer tow turn/stop relay
7 30A* High beam headlamps / Flash to pass
8 — Not used
9 20A* Heated mirrors
10A* A/C clutch
11 20A* Radio (main)
12 20A* Cigar lighter / OBD II
13 5A* Power mirrors/switches
14 15A* Daytime running lamps
10A* Driver’s seat module memory
16 15A* Rear seat controller
17 15A* Exterior lamps
18 20A* Turn lamps/Brake on-off switch (high)
19 10A* Body security module/4x4 module
— Not used
21 25A* Rear wiper motor
22 20A* Engine control
23 20A* Engine control
24 15A* Air suspension
10A* 4-Wheel Anti-Lock Brake System
(4WABS) module
26 10A* Airbags
27 15A* Ignition switch Run feed
28 10A* EATC module module/Front blower relay
coil
29 10A* Customer access
Fuse/Relay
Location
Fuse Amp
Rating
Description
30 15A* Highbeam headlamps
31 15A* Clutch interlock switch
32 5A* Radio (start)
33 15A* Front wiper
34 10A* Brake on-off switch
35 10A* Instrument cluster
36 10A* PCM Keep-Alive
37 15A* Horn
38 20A* Trailer tow park lamps and backup lamps
39 — Not used
40 20A* Fuel pump
41 10A* Instrument cluster
42 15A* Delayed accessory
43 10A* Fog lamps
44 10A* PATS module, transceiver
45 10A* Ignition switch Run/ Start feed
46 10A* Left-hand lowbeam
47 10A* Right-hand lowbeam
48 10A* Rear wiper motor
101 30A** Trailer tow electric brake
102 30A** Door locks/Body security module
103 50A** Ignition switch
104 40A** Heated backlite
105 30A** Injector driver module
106 30A** Front wiper main
107 40A** Front blower motor
108 40A** Auxiliary blower motor
109 30A** Heated seats
110 50A** Ignition switch
111 30A** 4WD/Shift on the fly
112 30A** Left-hand power seats
Fuse/Relay
Location
Fuse Amp
Rating
Description
113 30A** Starter motor
114 30A** Right-hand power seats
115 20A** Trailer tow battery charge
116 30A** Ignition switch
601 30A CB Door window motors
602 60A** 4-Wheel Anti-Lock Brake System
(4WABS) module
210 — Not used
211 — Not used
212 — Not used
301 — Front blower motor relay
302 — Powertrain (EEC) relay
303 — Injector driver module relay (Diesel
only)
304 — Heated backlite relay
305 — Trailer tow battery charge relay
306 — Delayed accessory relay
307 — Starter relay
* Mini Fuses ** Maxi Fuses
Top Maxon Radio Communications Experts
eradiostore
eradiostore
Johnny 1000
Are you a Maxon Radio Communication Expert? Answer questions, earn points and help others
