SOURCE: pcg-3e2l will not boot beeps repeatedly after
It's very simple. Either your "W" key is stuck or the membrane under the "W" key is damaged.
This would cause your notebook to beep repeatedly at start-up.
There's a simple way to check - press the "W" key several times and see if it feels normal (normal means that it feels exactly like all the other keys). If the key feels normal, then you have probably damaged the membrane but it could also be something stuck underneath.
SOURCE: I've got a Sony vaio which now on starting up has
Does it seem like it booted up all the way except the screen is black? If so try the steps below.
Shine a flashlight on the dark screen to see if you barelysee the icons on the desktop. If so, then the LCD Inverter is bad.
Plug in an external monitor and see if the display shows up on it. It can beany kind of monitor even the old big fat crt monitors as long as it has a vgacable to connect to your computer's vga port. If so that proves yourvideo card is ok. The video will show on most systems when you rebootwithout you having to do anything. Some systems will require you to hit the FN(Function key) + F1 thru F12. Hold down the FN key then hit the correctkey for displaying on the monitor (F1 thru F12). The correct key willnormally have CRT/LCD on it or it will have the icon of a display.
If you see no icons by shinning a flash light and the external monitor works,then your screen is bad. If you see no icons by shinning the flash lightand nothing shows on the external monitor, then most likely your video card isbad.
SOURCE: Reformat system - for Sony Vaio - part 2
You have to create the recovery cd using the Sony Recovery Media kit creator program.
It should be in the control panel. It requires 1 DVD and 1 CD-R cd. Or 7 CD-R cds.
You can however use the recovery wizard, but it will erase the Recovery Media Kit. It also can be found by using the recovery wizard in the control panel.
http://www.pctechbytes.com/vaio-recovery.htm
http://esupport.sony.com/perl/news-item.pl?mdl=PCGFRV27&news_id=8
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
SOURCE: no lights and screen is black seems dead.
I'm getting the following error message
"ntlbr is missing". what can I try
SOURCE: Won't boot up,black screen says operating system not found.
well its tough to say, could be a harsh virus, or damaged registry. Try starting it up and as soon as it starts press f8 repeatedly until the safe mode menu is prompted, then from there pick a the option that best suits you, either safe mode or safe mode with networking. In just regular safe mode you can go in and remove harmful data from your hard drive. Maybe running under last know configuration might help. Let me know what happens.
Here are a few things you can do or try
Restart the computer. If you are already in Windows, you can do this from the Windows Start menu, go to Turn off computer and click Restart. As the computer restarts, watch for a progress bar at the bottom of the screen. press F8 about once every second. Immediately press F8 before the progress bar reaches the right side of the screen. From the Windows Start-up menu, highlight Safe Mode and press Enter. Wait for your desktop to appear, and then make the necessary repairs (for example, uninstall programs or devices). When the repairs are done, restart the computer, and allow it to boot normally.
Alternate:
From the Windows Start menu, click Run. In the Open field, type MSCONFIG and click Ok. On the BOOT.INI tab, check /SAFEBOOT.
Click Restart when prompted.
Turn Off the computer, now as soon as you hit the power button, keep on holding "Alt" key & keep on tapping "F10 key,ie: Alt+F10, it will open the recovery console ,select full factory restore and follow on screen instruction. (Note:this will erase all datas on the computer)
or
During the boot process you will see on the screen to press a certain key to enter setup
Press and hold that key during the boot up process to enter BIOS you can load failsafe defaults or load optimized defaults ,press escape then press f10 to save to cmos to restart
click start all programs accessories scroll to system tools from there you should see a system restore click next a sytem date should open up select the date you want to restore your computer to or if you want a full factory restore or
Turn Off the computer, now as soon as you hit the power button, keep on holding "Alt" key & keep on tapping "F10 key,ie: Alt+F10, it will open the recovery console ,select full factory restore and follow on screen instruction. (Note:this will erase all datas on the computer) or
Hope this helps don't forget to vote
Alternate:
or
Alternate:
or
