Question edited for clarity and spelling of maker 'atvia' to 'Ativa'.
If it is only running in reverse the most likely cause is a faulty switch as the switch just reverses the polarity of the power to the motor. Also check that nothing is covering the proximity sensor in the throat of the shredder.
The shredder will only constantly run in the "Reverse" mode. The trigger located in the center of the feed entry slot, which activates the shredder, may be blocked. To clear it, you would need to insert an index card or file folder (i.e. rigid paper or cardstock) in the center of the feed slot and apply force.
Jammed ativa shredder, works in reverse, won't go into auto.
JustAnswer
https://www.justanswer.com > office-equipment > c79...
Mar 24, 2019 - Rotate the shredder into "Auto" and reverse to loosen any paper jam that is stopping the gears. Pull out any papers that are sticking out from ...
1 answer · Top answer: Let the shredder cool down if the shredder has been running continuously for a long time. ...
Why does my paper shredder operate in reverse only? '
KnowledgeOwl
https://fellowes.knowledgeowl.com > help > why-does...
Apr 13, 2022 - This likely has to do with the auto run sensor of your shredder not being engaged correctly. On small shredders, the sensor is normally a ...
