My tub/shower uses a Tub/Shower compression Diverter part #: S10-385. I now need to buy the hot and cold stems. So, which is the correct part # for the hot and cold stems? 1) Is it the 910-374 ? 2) Is it the S10-375? 3) Is the S10-375 discontinued? 4) Does the 910-374 replace the S10-375, but BOTH will work? 5) Also, does the 910-381 Diverter replace the S10-385? Is the S10-385 Diverter discontinued? My local Lowes store still carries the S10-375. Can I use that part for my hot and cold stems? Please answer all 5 questions so I can understand it all. And please let me know if the 910-374 and the S10-375 are the SAME part and are interchangeable.
SOURCE: The cold water stop working in my shower. I have a
Two posebel coses i can think of.
1. the taps plunger is stuck in the off posision or 2. there is dirt loged in cold side of tap.
take off head part of cold tap and c if mabe the rubber is stuck or if u maby see some dirt in the tap ietself
hope it helps
SOURCE: Have a shower only no tub. replaced both the hot
Take the shower head off and see if the pressure is better or the same. If it is the same then you will need too look up-stream for blockage in the water lines. If it is better then replace or clean out the holes in the shower head. It may also have a filter screen before the shower head.
Testimonial: "I wasn't sure if that was the problem since I had just recently put a new shower head on, but it was the problem. Thank you for your help. "
