This watch automatically sets itself. I you live in the eastern time zone, you just have to wait for the watch to receive the signal then it will set itself to the correct time & date. The signal is strongest at night between the hours of 10:00 pm & 2:00 am so it normally takes over night to set. Sometimes the weather interferes with the signal so I tell people to give them a couple of days to pick up. Also if you are having trouble receiving the signal try placing the watch by a window. If you do not live in the eastern time zone try these instructions:
Hold down the button for 2 seconds until the time zone abbreviation & zone flash the keep pressing the button until your correct time zone is displayed. Then wait about 8 seconds for the watch to return to normal display. Then you just have to wait until it picks up the signal & sets itself. I hope this helps. This watch automatically sets itself. I you live in the eastern time zone, you just have to wait for the watch to receive the signal then it will set itself to the correct time & date. The signal is strongest at night between the hours of 10:00 pm & 2:00 am so it normally takes over night to set. Sometimes the weather interferes with the signal so I tell people to give them a couple of days to pick up. Also if you are having trouble receiving the signal try placing the watch by a window. If you do not live in the eastern time zone try these instructions:
You can't post conmments that contain an email address.
In time mode, hold set (bottom right button) to change date and time. The selected (flashing) item can be changed in one direction only using the up (top right) button. Press set again to cycle through each item until desired settings are chosen. In stop watch mode, the up button starts and stops the stopwatch, the set button will take a split time while the time is running. To reset the stopwatch, press set once while the time is stopped. In alarm mode, the up button turns the alarm on and off. There are three alarms available. To cycle though alarm times, press set. To set an alarm, press and hold set until the time flashes, then set the alarm time using the up button, cycle through hour and minutes using the set button. When finished, press set again. Timer mode. To set the timer time, press and hold set until the time flashes. The timer goes up to 23h:59m:00s. You cannot set seconds. Once set, the timer can be started and stopped using the up button. There is no reset for the timer, to start a new timer the time must be manual changed again. To check heart rate, press and hold mode until PUL is shown, place two fingers, one each on the top and bottom metal contacts for 6-10 seconds to get reading (This works best when not in motion).
My watch has model number 504-tsk085, labeled Timex 1440 Sports, and Timex provides the incorrect manual for it online. I wrote these instructions after careful experiment:
Upper left button: press to switch to a stopwatch, or...
Press and hold to enter alarm setting mode. Once flashing press again to enter time/date setting mode.
-- you can only do one or the other without exiting the setting
mode (time or alarm set).
- within the setting mode you use the two right side buttons
in obvious ways to set times/dates
Exit setting mode by pressing upper left again
Lower left button: light
Upper right button (when not setting time): reveal date while pressed
Lower right button (when not setting time): reveal alarm time while pressed.
ALSO: WHILE lower right button is pressed you can change alarm
on/off and chime on/off through the four possible settings by
secondarily pressing the upper right button repeatedly.
Hi there I see that you are in need of assistance setting time on your Armitron Wrist watch.
I would be more than glad to give you details on how to, Please see steps below.
Your Armitron Watch will have Four Button on the side of the watches rim.
Button on the upper Left is MODE.
Button on the lower Left is LIGHT.
Button on the upper right is DATE.
Button on the lower right is Alarm.
See Steps below: *Setting the time*
Press and Hold down the Mode Button til the Hours flash
Then push Alarm Button to set the Hours
Press and Hold down the Date Button till the Minutes flash, then push D/Alarm Button to set the minutes
After setting the minutes on your watch, Press date till you get the month flashing push Alarm to set the month
Press the Date again till the Date flashes, then push Alarm to set date
Press the Date again till the Date on your watch flashes, then push Alarm to set the date
After setting everything push the Mode Button again just once to set everything or finalize your settings on the watch.
I hope that this will be of help regarding your query on how to set the time on your Armitron watch, I also included the setting of the time and date just for further details.
I will be glad to help you with your concern regarding your Armitron
Wristwatch, what exactly would you be experiencing? cause I only put
info on how to set time and date on the Watch.
Please see below steps:
Button
Button on the upper
Left is MODE.
Button on the lower
Left is LIGHT.
Button on the upper
right is DATE.
Button on the lower
right is Alarm.
See
til the Hours flash
Press and Hold down
Minutes
flash, then push Alarm Button to
set the minutes
watch, Press Date
Press the Date
Alarm to set date
the date
I
Here's how you set the 40/6623 M175 for anything. I figured it all out with help from here :). Okay so want to set the alarm? Press MODE once. Then hold it. And use the DATE and ALARM buttons to set the alarm. Press MODE twice and you're done. To set time do the step before this and press MODE once. Use the DATE and ALARM button to set the time. As for the 24 hr deal what you do is hold ALARM and press MODE or hold MODE and press DATE. To turn alarm on/off hold ALARM button and then press the DATE button. To set the date go to time set mode and keep cycling between the hours and mins until you get to the date :). That's all you gotta do :D. I know many of you need the instructions so here it is!!
*C/*F KEY TO TOGGLE BETWEEN TO TEMPERATURE FORMAT;
SNOOZE BUTTON TO SET SNOOZE IN ALARM-MULTIPLE SNOOZE CAN BE SET;
RESET KEY CAN BE USED TO RESET CLOCK TO DEFAULT;
DAY COUNTDOWN , AND TIME COUNTDOWN CAN BE ADJUSTED;
DETAILED INFORMATION TO SET THE CLOCK
INSERT CELLS;-SCREEN SHOWS DEFAULT VALUES-INITIAL MUSIC WILL RING; LONG PRESS MODE BUTTON-KEEP IT PRESSED UNTIL 12 STARTS BLINKING; USE UP /DOWN BUTTON TO ADJUST HOURS... THEN SIMPLY PRESS MODE AGAIN, NOW MINUTES 00 IS DEFAULT WILL START BLINKING; USE UP/DOWN BUTTON TO ADJUST MINUTES; AGAIN PRESS MODE, SCREEN WILL SHOW YEAR 2002 DEFAULT BLINKING, USE UP/DOWN KEY TO ADJUST YEAR; AGAIN PRESS MODE, SCREEN WILL SHOW MONTH BLINKING, USE UP/DOWN KEY TO ADJUST CURRENT MONTH; AGAIN PRESS MODE, SCREEN WILL SHOW DATE BLINKING, USE UP/DOWN KEY TO ADJUST YEAR; AGAIN PRESS MODE, SCREEN WILL SHOW 12:00 BLINKING WITH ALARM SIGN (FOR ALARM SET);USE UP/DOWN KEYS TO SET ALARM, FIRST HOURS AND THEN MINUTES FOR ALARM; THEN ON PRESSING YOU CAN SELECT SNOOZE MINUTES; AFTER SNOOZE ON PRESSING MODE AGAIN YOU CAN SELECT DAY COUNTDOWN TO SELECT 999 DAYS COUNTDOWN FROM CURRENT DATE;
when watch displays time and everything ..... each and every buttons has some function;(shortcuts) press down to toggle between 12hr/24hr format; press up to enter contdown timer; press snooze to set snooze in alarm; press c/f to toggle between two temperature formats; press mode to toggle between alarm time and current time
Armitron All-Sport Watch Instructions
By Brian Walker
eHow Contributor
9 Found This Helpful
The Armitron All-Sport is a unisex style of watch made by Armitron that features a digital readout and four buttons around the outer dial for adjusting various aspects of the watch. It can set alarms, keeps the time as well as the date, and has a built-in backlight. Accessing and adjusting these various settings is a fairly simple process.
To enter the date and time setting mode, press and hold the "mode" button, located on the top-left of the watch. Continue holding this button until the display begins to flash. This first display is the alarm setting, should you choose to set an alarm to go off. If you'd like to set the alarm, use the "alarm" button on the bottom-right of the watch to advance the hours to the desired one. Then press the mode button again; this will cycle through the minutes and seconds of the alarm to allow you to set those as well. Once you have set the alarm, you can press the "date" button at the top-right of the watch to proceed to the regular time setting. These numbers, which will now be flashing, also are adjusted by pressing the alarm button to change them. Pressing the date button again will now cycle through the hours, minutes, seconds and the date. As you continue to press the date button, the All-Sport will continuously cycle through these options; don't worry if you forget to set one, you can simply press the date button a few times until you get back to the setting you need to change. Once the alarm, time and date have all been set, you can press the mode button one more time to exit to the normal watch mode that will display the date and time.
Using Chime and Alarm
The Armitron All-Sport features both an alarm and an hourly chime. The alarm function will cause the watch to continuously beep at the selected time until you turn it off by pressing a button. The chime will cause the watch to beep once every hour. You can turn both these features on and off by pressing and holding the alarm button and while holding it pressing the date button. The first time you do this, the chime will turn on and a small house symbol will be displayed on the watch face. Performing this button-pressing sequence again will turn on the alarm, which in turn displays a small clock icon on the watch face. Each successive pressing of this button sequence will alternate between the chime and the alarm, turning them either on or off.
Backlight
The All-Sport also features a built-in backlight to help you view the watch in dark conditions. This light can be activated by pressing the "light" button on the bottom-left of the watch. Pressing this button is the only way to activate the light, and doing so will only cause the watch to illuminate for a few seconds at a time.
Setting my Aspen Digital Watch
Button designations:
(NITEGLOW)BC(START/STOP) 10:47 (MODE) AD(SPLIT/RESET)
To Set Time, Date and Day:
PressA3 times;Seconds Flash; Set to 00 with C
Press D;Minute Flashes; Set Minutes with C
Press D;Hour Flashes;Set Hours with C
Press D;Date Flashes;Set Date with C
Press D;Month Flashes;Set Month with C
Press D;Day Flashes;Set Day with C
Press A to Quit
To Set Alarm Time:
Press A2 times;Hour Flashes;Set Hour with C
Press D;Minutes Flash;Set Minute with C
Press A to Quit To Set Alarm ON or OFF:
Hold D in to see Alarm Time and Press C to toggle Alarm ON/OFF Operation:
Hold C to see Month and Day.
Hold D to see Alarm Time;Press C to toggle Alarm ON/OFF.
