Brother LS-2125 Mechanical Sewing Machine Logo
Posted on Mar 15, 2009
Bobbin won't thread on my Broter DB2 B755-3 Industrial Sewing machine and i don't have any instructions for it. collies
Anonymous
Level 1:
Problem Solver:
  • Contributor 5 Answers
  • Posted on May 29, 2009
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
5
Questions
0
Helped
20891
Points
25
Manual here........
http://myweb.tiscali.co.uk/stitches/BROTHER-DB2-B755-MKIII-MANUAL.pdf
1helpful
I have a Brother Exedra DB2-B737-403 industrial machine. How do I wind the bobbin?
It's an industrial machine. You use a stand-alone bobbin winder.
https://www.amazon.com/bobbin-winder/s?k=bobbin+winder
Look, no bobbin winder.
https://www.ebay.com/itm/264059721244
From my EXTENSIVE research on your behalf, it was an optional attachment.
Contact Us ' Brother Solutions Centerhttps://support.brother.com > contacttop
Others. Support & Downloads. Contact Us ... Before contacting Brother, we recommend that you refer to the FAQs available for your Brother product. Submit.
tip
Sewing answers
manuals can be found at,
ManualsLib Makes it easy to find manuals online
singer manuals and support,
Customer Support
tips and hints,
Sewing Resources
how to videos,
SingerSewingCompany
presser feet tutorials,
SingerSewingCompany
singer replacement parts,
Replacement Part Availability
parts for ANY machine,
http://www.sewingpartsonline.com/
household machines,
Sewing Machines
industrial machines,
Industrial Sewing Machines
babylock,
http://www.babylock.com/support/faq
singer manuals.
Instruction Manuals
Troubleshooting/Frequently Asked Questions
Please click on any question below to display the corresponding answer.
Basic Tips for All
  1. Always turn the handwheel TOWARDS you (counter clockwise) as turning it in the opposite direction (away from you, clockwise) may knock the timing out requiring repair from a service center.
  2. Always be sure your presser foot is in the DOWN position before sewing. Sewing with the presser foot in the up position will cause your thread to tangle and your bobbin to jam.
  3. Change needles regularly (after 16 hours of use) as dull/weak needles can cause damage to your machine and fabric. Only use SINGER needles on your SINGER sewing machine.
  4. Always be sure you are using the correct bobbin for your machine. Class 66, Class 15 and Class 15J bobbins look very similar. However, using the incorrect bobbin class in your machine can cause damage.
on May 24, 2015 • Sewing Machines
Hi I have a Brother DB2-B755-3 Industrial Sewing Machine which siezes solid after about 5 seconds of sewing, i have recently cleaned it throughout, Removed the Bobbin and Bobbin case, also the needle
Hi there, the most common Robles with these sewing machines is seizure, and all it takes is a little oil, around the mechanism, try this, it should loosen up after that... good luck
1helpful
Brother DB2-B756-5 Industrial Sewing Machine
contact brother website and go to support and click on it
you'll see online support center there will be 4 boxes , choose
number 3 customer support , it has numbers on the box and click
on it, they have a live chat, try that
5helpful
I have a DB2-B797 and have lost the threading instructions. This is an older industrial model. Nesting is on the bottom of the material when sewing. Do you have instructions for proper threading of this...
Here are some pictures. Hope they help. If not I can attempt to describe how to thread. Good Luck. Well, I can not get my photo size below 150 kb as required to post. So, if you want to email me I will send it via email. [email protected]
1helpful
Brother Industrial Machine Tension
This is an answer to another person with a similar complaint. Try the suggestion below, it may fix the problem.
From your description it appears that you have tried tension settings on the upper tension control adjustment knob without success.
Check that the bobin tension is adjusted correctly by taking out the bobin complete with the spool.
Pull the cotton thread and it should be a smooth light pressure if the tension is correct. If it is tight to pull or pulls freely then adjust the tension screw which is found on the outside of the bobbin. The screw is very small and requires a minature size screwdriver. The adjustment will only be a slight turn of the screw one way or the other to obtain the correct tension(depending if it was loose or tight).
Once this is set reinstall the bobin and tread up the machine, hopefully with the upper tension set at approx."2" the machine will sew correctly.
Industrial sewing machine top thread breaking
The brother DB 2 series of machines do not use a needle with a flat side. the needle system is DBX1 and are available from size 10 to size 20.
Try using the right needle for the machine and the right size for the thread you are using. this should make it better
25helpful
8answers
Brother DB2-B755-3 industrial sewing machine
I have the manual in pdf form here
Top Brother Sewing Machines Experts
Mike Cairns
Mike Cairns
Paul Bade
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
