While cooking dinner, I opened oven to turn meat and noticed inside light flicker a few times. I turned my burner up on high to get water to boil---nothing. The exhaust fan ran until the oven cooled down but the clock went out and nothing would work. Tried to rest the breaker-nothing. I tried the burner again and the range made a weird noise, the clock blinked but nothing. After about 12 hours, the burner was in the on position, same weird noise,clock blinked except when I hit the cancel button---clock worked. Tried to use the stove top to boil water but didn't make it to boil before it quit again. I give up! Please, any ideas????
Shut the breaker off! These are the exact symptoms that a tenant of ours reported for their range. I went to check the range and found that one of the power wires on the terminal block in the back of the range was burning itself up. It had actually started a small wire fire. You need to pull the range out of it's hole and unplug it. Remove the panel in the back above where the cable goes into the range. Examine the power wires and terminal block carefully, because I bet you'll find one of the wires is burning up and needs to be repaired. Please write back and let know what you find.
THANKS!!! My mom said my stove smelled like it was burning and I just thought it was something on the stove top. Makes sense now and I will check it out ASAP!!!!! Any idea why this would keep happening? This will make the 3rd service call and the range is only 18 mos. old. Thank you!!!
Please help me
The oven and cooktop both stopped working
