Locate
the manual for your television. Though slightly embarrassing, accidentally
turning on the child lock to a TV is a common problem. The section In the
manual about how to set the child lock feature will also explain how to unlock
it.
Try
a few "universal methods" for unlocking the child lock. Some
televisions have a universal code built in for disabling the child lock --no
matter what your code is. A common code is "0000."
Unplug
your television for a few minutes. The internal battery of the TV is what helps
remember what your code. If the TV is unplugged for an extended period of time,
it clears the internal memory, which in turn will reset your child lock code.If
you wish to get more details, check the site linked below. Pull up older posts
there. Check the site with patience, as
it has over 2400 posts now. All are
related to electronic equipment repair help.
If you search the site in Timeslide option, which can be selected from
the drop down list at the top left of the display window, it will be easy to
locate the related post. You can also
do a search by type in the brand name to your device into its search box at the
top right of display window.
Press the LOCK button to lock or unlock the TV.
When the TV is locked, the screen will turn to blue background, and nothing can be viewed unless you press
LOCK again to unlock it.
OK
[Sometimes you may need to press the LOCK button more than 5 seconds contnously to unlock the TV]
OK.
