Microwave Ovens Logo
Anonymous Posted on May 02, 2013
Samsung microwave disorienteted
When I press the one minute button the oven start normal, when I open the door after 30 sec the time counter is still running to zero after that the turntable starts turning slowly and the light is dimmed like something running on a flat battery. Please help
William Miller
Level 3:
  • Microwave Ovens Master 9,179 Answers
  • Posted on May 03, 2013
William Miller
Level 3:
Answers
9179
Questions
Helped
4481631
Points
21747
It may juts be a bad door switch or mount. See our help fil on door switches here:
http://031d26d.namesecurehost.com/mwd/doorsw.txt
If you still need help, please post a new help request with the full model number from the tag in the cooking cavity or elsewhere on the microwave, such as the door frame, controller frame, etc.
5 Related Answers
MicrowaveSvc
William Miller
  • 9179 Answers
  • Posted on Sep 23, 2006
SOURCE: Smasung MW7490w door/turntable problem
It's probably a defective door switch, probably the upper one, or the mount which holds the switch is broken. Opening the door while cooking (without first hitting the STOP button) is the primary cause of door switch failure. There are plastic mounts inside the microwave which hold the door switches and onto which the door hooks latch when you close the door. The screws on these mounts may be loose. If they get too loose, the switches will not be activated properly. Usually it's not a loose screw, but instead a broken tab on the switch holder, allowing the switch to rotate just out of position.
MicrowaveSvc
William Miller
  • 9179 Answers
  • Posted on Nov 26, 2007
SOURCE: when I open my microwave door, it starts running
In most cases, it's not actually cooking, but instead the fan, turtable and light may be on. Yet it does need attention.
What this usually means is that you have a shorted door switch or a bad door switch mount.
It's easy to tell if it's actually cooking, just place a cup of water inside and see if it heats.
If so, that could mean a stuck relay on the control board. If so, we repair these for customers nationwide with our guaranteed $39.95 service. Far less than a new board.
If you or a friend decide to look into it, we have critical safety information, info on door switch diagnosis and replacement, and
disassembly information at our site, linked here on Fixya: http://tinyurl.com/yzjozk
Please write back with more details if you need further help.
We're happy to help and we appreciate your thoughtful rating of our answer.
MicrowaveSvc
William Miller
  • 9179 Answers
  • Posted on Nov 28, 2007
SOURCE: Maytag Microwave MMV1153
First of all, it's under warranty. So I would contact Maytag for a free fix.
See http://maytag.com/support/service_parts.jsp
For an out of warranty reply:
This is usually caused by either a bad door switch, a loose door switch mount, or a problem on the control panel.
Even though a door switch clicks, it may still be bad inside.
If you or a friend decide to look into it, we have critical information on safety, disassembly and door switches at our site, linked here on Fixya: http://tinyurl.com/yzjozk
MicrowaveSvc
William Miller
  • 9179 Answers
  • Posted on Apr 18, 2008
SOURCE: Microwave oven runs with door open
This is usually caused by either a bad door switch, a loose door switch mount.
Even though a door switch clicks, it may still be bad inside. Its continuity must be checked.
Door switch or mount trouble can be caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
If you someone you know decide to look into it, we have critical information on safety, disassembly and door switches at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
You can find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
Please feel free to contact me directly if you need more help.
William E. Miller, AS-EET
[email protected]
http://www.microwavedisplay.com
MicrowaveSvc
William Miller
  • 9179 Answers
  • Posted on May 02, 2008
SOURCE: turntable microwave oven (model JE1540WW 002) (serial ZR943877S)
Chances are that it is not actually microwaving, but that can be checked by placing a small cup of water inside.
Overall, though, it's not a good idea to run it if it's not working right.
This problem is usually caused by either a bad door switch, a loose door switch mount, or a problem on the control panel.
If you or someone you know decide to look into it, we have critical information on safety, disassembly and door switches at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
There should also be a "mini-manual" hidden inside the unit behind the control panel, which is very helpful when troubleshooting.
If you think the problem is on the control panel, we repair these nationwide by mail for $39.95 postpaid in most cases.
[email protected]
1helpful
Microwave let's you set the time to cook but when you press the button to start the process nothing happens
Try a power disconnect at the plug socket for 5 minutes. If that doesn't reset it, you will need a local repairer. The most likely reason is a door safety micro-switch has failed or moved out of adjustment. There are normally three on the door and hinges to prevent operation with an open door.
https://www.fixya.com/support/r29874712-repairing_microwave_ovens
2answers
How to fix the door button on panasonic microwave t6648fx?
Clean the inside edge of the door and oven where it contacts the door. Grease or oil is preventing the door to swing open.
Microwave oven will not start but the light stays on even when door is open.
One of the micro switches in the door is stuck ( faulty ) there are normally 3 switches so after removing the lid open and close the door and you will see the door latches pressing in the button of the micro switch and one of them would indicate that one of the switches is not in line with the latch to press the button in or one of the micro switches has melted inside cosign the switch to release normally open or normally closed, you need a multimeter to test the switches in that case
Door button does not function for panasonic microwave=need to know how to take the face off so that I can fix it
Take side panels off and press the button through from the back, my husband has just done this tonight on our Panasonic microwave model NN-ST477 as the door would not open. He found a piece of plastic like a hook had snapped off. The door now opens and functions normally. Took about 30 minutes to do . If and when it becomes stuck again we know that we will need a new replacement button. Hope this helpskind regardsChristine
1helpful
Does the exhaunst fan turn on automatically when we cook or warm food items in our Samsung Microwave -- SMH 9187W?
Some interesting reading on page 8 of the owner's manual:
"Boilovers cause smoking and greasy spillovers that may ignite and spread if the vent fan is operating.To minimize automatic fan operation, use adequate sized cookware and use high heat on surface units only when necessary."
And on page 20:
"If the temperature becomes too hot around the microwave oven, the fan in the vent hood will automatically turn on at the LEVEL 2 setting to cool the oven. The fan will automatically turn off when the oven has cooled down sufficiently. This is an automated process and cannot be turned off. The fan may stay on for 30 minutes or more after the cooktop and microwave controls are turned off. The Vent Fan will only operate in 1~4 levels modes while the microwave is working."
"Using the Vent delay off button
1. Press the Delay Off button once to turn the fan off after 1 minute.
2. Press the Delay Off button twice to turn the fan off after 3 minutes.
3. Press the Delay Off button three times to turn the fan off after 5 minutes.
4. Press the Delay Off button fiour times to turn the fan off after 10 minutes.
5. Press the Delay Off button five times to turn the fan off after 30 minutes."
If for some reason you don't have your owner's manual, you can still download it free here.
We're happy to help you with free advice and we'd appreciate your thoughtful rating of our answer
2helpful
4answers
I have Emerson Microwave #mw8999sv which has the Express Cook option- cooking 1 - 6 minutes. How do I cook for 1 minute 30 seconds, etc.? Thank you.
The owner's manual is here. On page 10 we find:
COOKING IN ONE STAGE
1. Press the POWER button; the Microwave and High
Cook indicators will light and “PL 10” will light in the
display.
2. Press the POWER button different times to set the
desired power; the display will show the percentage
you chose. If selecting power level 70%-10%, the
Low Cook indicator will light instead of the High
Cook indicator.
3. Press number keys to set the desired cooking time.
OPERATION(CONTINUED)
4. Press the START/+30SEC. button to start cooking;
the Microwave and one of the Cook indicators will
blink and the display will countdown the remaining
cooking time in minutes and seconds. It will beep
five times when cooking is completed.
I have a Whirlpool gold accubake microwave / oven combo model number GMC305PDS07. The microwave will not turn on and will display "DOOR". I think it is thinking that the door is open?. Please help.
Press and hold the DELAY START TIME button for +5 secs and a chime will sound. The option to toggle between SND HI and SND LO will come up, pressing Delay Start Time will change it between these options.
2answers
Door
What usually breaks is the door open lever.
On a counter top model, the outer cover will need to be removed to diagnose and repair this. On an over-the-range model, only the control panel needs to be removed.
Please unplug the oven first.
If you or someone you know wants to look into this, we have critical safety, disassembly, and troubleshooting info at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
Once it is apart, you'll be able to see how the door open button would press against the door open lever, which would then lift up against the door latch heads (hook-like projections on the door) and the door should open.
If you reply back to this with your brand and model number, we can steer you toward a part source, and possibly toward exploded view diagrams, etc.
Top Microwave Ovens Experts
ZJ Limited
ZJ Limited
john h
Are you a Microwave Oven Expert? Answer questions, earn points and help others
