Question about Jamo SW400E Speaker
Jamo Sub with no power
I Also have a Jamo SW410E sub ang I have tryed everything and still won't power up. any Ideas?Thanks
  • Anonymous Mar 16, 2014
    No sound
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 137 Answers
THE IS A FUSE INSIDE THE UNIT,YOU MAY WANT TO CHECK THAT.IF IT BLOWS AGAIN WHEN TURNED ON YOU HAVE SHORTED MOSFETS. THEY ARE LIKE TRANSISTORS.
Posted on Apr 20, 2010
SOURCE:
I brourt a jamo sub 200 and five a102speakers but
The Jamo speakers need an AV Receiver to drive them properly. The TV doesn't have the correct outputs nor does it have the power required.
The Jamo kit consists of a powered subwoofer ans 5 small surround speakers. Each surround speaker needs to be powered by the speaker output from an an AV Receiver. The subwoofer should also be connected to the receiver, but the connection is a phono/RCA lead from the receiver's "Sub Out" socket.
Your TV connects to the AV receiver via the Optical out.
Aug 31, 2014 | Audio Players & Recorders
Hi My problem is that my Jamo 200 sub sounds very
Is everything hooked up correctly sounds off I know also could be your amp is going on you cold be a multitude of problems or one of the simple ones i stated
Oct 26, 2013 | Jamo SUB 200 Subwoofer
Jamo sub 250
Internal power? Check fuses. No fuses? Disassemble and check Power supply if it is internal. If it is external, check power supply with meter.;.
Apr 30, 2013 | Jamo SUB 250 Subwoofer
I have a jamo 200 sub and jamo s602 speaker how do i wire so i can listen to music from my ipad to the speakers
the easiest solution is to get yourself a cord that switches from headphone plug to RCA and connect it that way. I sure hope that this helps you in hooking your ipad up to the Jamo 200 Sub. Thanks, Cody
Sep 13, 2012 | Jamo SUB 200 Subwoofer
I have a JAMO SW410E subwoofer and would like to connect it to my Panasonic SA-PM19 stereo system, Im not sure if its possible but I would like to know if i can and how to do so. Thank you.
Sorry to said but Jamo SW410E is an active subwoofer. This means that is has his own amplifier for the speaker (that why you can see at the back panel of the sub the RCA connectors for Left and Right (line in level):
In the meantime your Panasonic SA-PM19 stereo system has none connector for audio out (except the one for the heaphones). So it's not possible to connect these 2 audio devices together.
In case of a problem or clarification or further details needed, don't hesitate to post me a reply before rejecting my answer.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Thanks and regards
Please kindly rate this solution
Stelios
direct FixYa link: http://www.fixya.com/users/technical114
Aug 03, 2011 | Panasonic Audio Players & Recorders
I have a jamo 250 sub and dont know which coax input to use
one will do just fine if you've tried one and its not working try to refer to manual on how to set up in the receiver function menus and if the sub is powered by an external amp which most are
Jul 03, 2009 | Jamo DVR-50 System
JAMO SUB 650
hi
since it is a powered speaker, probably it just needs a sound signal which you can get from the headphone socket. please double check with someone else.
May 26, 2008 | Jamo D 4SUB Subwoofer
I have no amp for jamo 1060 sub
Dual Voice-Coil
The unique Dual Voice-Coil design allows both left and right channel sound from just one speaker. Simply hook up both the left and the right channels to the special terminals on the speaker. Hook up one channel only, if the speaker is to be used in a conventional stereo set-up.
I found this on jamo site hope that will help you
Mar 15, 2008 | Jamo 1060 SW Speaker
607 people viewed this question
Top Jamo Audio Players & Recorders Experts
 Grubhead
Grubhead
rjivaro
Robert Rankin
Are you a Jamo Audio Player and Recorder Expert? Answer questions, earn points and help others
