This works for most tomtoms so there is nothing to loose and everything to gain
Remove the
SD cardThe card needs to be formatted properly first
that's all,
formatting is better done in a card reader.(opionions vary)
Right click on it and select format select FAT32 as the files system
Now
connect the
tomtom but
don't let
tomtom home run. exit
TTH if need be.
You now ned to select your tom tom which will also show as a drive.
In windows explorer select tools then folder options. Click view and tick the box for "show hidden files and folders"
It may warn you but you can ignore it.
then just copy ALL the files from the tom tom to your sd card
DO NOT USE CUT AND PASTE !
Once all the files are on
switch off the tom tom and insert the sd card
It should now work
