Question about Karcher K2.26 Electric Power Washer
Karcher/Winner 11 - motor pulses when hose is not operating
As above motor pulses every 4-5 seconds when power is on but hose gun is not in use.
    New Friend:
Hi, I had the same problem, Replaced the O rings and the rubber seals and cups inside the pressure washer and eventually the hose itself burst. Turns out the hose was leaking, internally between the inner sheath and the outside plastic cover, for quite some time and this caused the pulse. New hose and pressure cleaner is as good as new.
Posted on Mar 12, 2010
    President:
  • 389 Answers
This is a common problem, caused by a slow leak somewhere in the high-pressure side of your machine. Unfortunately there are several possible root causes, most of which are not user-repairable (unless you are particularly mechanically-minded).
The simplest possible causes are external leaks, either in the trigger mechanism (is the spray nozzle dripping, even very slightly, with power on but gun not in use?) or where the high pressure hose connects to the machine (is the O-ring in good condition and well greased?).
If all seems well in these two places, then there's an internal pressure loss (which, again, can have several causes) that probably needs professional attention.
If this doesn't help, or you need more information, please post here again and I'll do my best for you.
Posted on Mar 15, 2009
SOURCE:
Karcher Leaking from Back or inside...Help please
Karcher pressure washers are very sensitive to over-winter freezing. The plastic parts break, and you have to replace all of the leaking parts.
You may be missing a locking tab, without seeing the thing apart next to the exploded parts view, it's really hard to tell. Search google for "karcher parts", and put in your model number...
Aug 03, 2015 | Karcher Garden
I have a karcher kb9020 which pulses when idol any ideas why
The "manifold" as talked about above is also called the "Control head".
For a picture of the very small cracks in the control head see here: Karcher Control Head cracks
The video linked to below talks about the cracks in the control head at 7:00 through to 7:08. They guy incorrectly calls it the cylinder head in the video. How to FIX Karcher pressure washer
If Karcher made the control head from an aluminium casting, or used a metal insert near the point of failure, their product range would be a LOT more reliable.
May 30, 2014 | Karcher PSI Electric Pressure Washer
Karcher gun leaking
the gun needs replacing, non servicable, interchangable with many brands
Mar 21, 2014 | Garden
Where can I get an online Instruction Maunual for the Karcher Winner 11
http://www.rjbowers.com/machine_list.php Click on blue search list box - type winner in box - hit enter key and the parts list and manual will come up. Or call RJBowers tomorrow and we will email the manual. 800-383-6584
Mar 31, 2012 | Garden
I have a Karcher K3.540 pressure washer. Won't take up detergent and motor pulses ever second if vari-lance increased towards maximim. Motor runs ok at lower pressure but can take 1min to start wh
This fault is within the control head, under the detergent valve is a small spring loaded valve that acts to induce the detergent, this will have failed, the shaft of the component breaks off the disk base leaving a small hole in the centre of the disk. This is enough to allow pressure past the component. The machine will pulse when operated and will not induce the detergent. I've looked everywhere to find this part as I have a karcher with the same fault.
Jan 22, 2012 | Karcher Garden
Cant get my soap dispenser hose working on my karcher winner 10, any suggestion?, lost my instructions manual so dont know weather i need to be doing anything for it!
If you have not yet found a solution, then here are some steps to take.
1. The soap dispenser only works on low pressure!!!!!!! So you have to REMOVE the high pressure Sprayer so that all you use is the Trigger Gun without the Extender.
2. Pull out the thin Plastic Hose with the filter attached in the end, and insert into your container of detergent.
It will only splatter the detergent over the area you want to clean, so you will then need to REATTACH the SPRAYER into the hand gun to work with the soap to lather, clean and spray of till clean.
This seems to be the way the system works on this model......also known as K2.36M (AU) in Australia or (EU) in Europe on the Karcher.com.au site then Service then Manuals. or on the link below.
Hope this helps any of you who has misplaced their Owners Manual just like I did and had a great problem trying to find a link as Karcher doesn't recognize the Model No: as Winner 10 or 11.
Cheers, Luke
Nov 19, 2010 | Karcher Vacuums
Hi I have a Winner 11 by Karcher. the hose blew a hole in it am wanting to replace it. The only numbers that I can find are N1417 or S/N185140 or Q60004 are any of these going to make it easier to work...
I have a parts breakdown for this unit in a PDF but they made about 3 different styles of hoses and trigger guns, if you send me a email at justin@wmpcs.com I can send you the breakdown and you tell me what one you need.
Oct 13, 2010 | Karcher K2.26 Electric Power Washer
Trigger gun
It sounds like you left out the spring in the hose.
There are about 10 different models of K330 with several types of guns. Go here and search until you find the correct gun so you can see the diagram. I think it will be hard to buy a replacement spring, though.
Aug 03, 2009 | Karcher K2.26 Electric Power Washer
Karcher pistol gun has broken
i do not think there is a pressure release valve , sounds like the plastic inside the pistol has become brittle and has failed under pressure , you dont say how old the pistols are ? and if you run strong detergents through them .
May 26, 2009 | Karcher PSI Electric Pressure Washer
Karcher K2.26 Electric Power Washer Logo
2,420 people viewed this question
Top Karcher Garden Experts
Martin Grech
John Trevino
JOHN LAPIER
Are you a Karcher Garden Expert? Answer questions, earn points and help others
