Polaroid SprintScan 4000 Film Scanner Logo
Posted on Mar 15, 2009
Where can i get a replacement lamp for SprintScan 4000?
And what is the part number? I have tried the "support" section on its web site without luck.
Thx a lot.
Thomas
  • tom_xx_hu Apr 12, 2009
    Do not see any solution. Am I missing anyhting?
Anonymous
Level 1:
  • Contributor 2 Answers
  • Posted on Apr 11, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
664
Points
Hi there, my sony grand wega kdf60wf655 had stopped working and was flashing 5 red lights. I tested the voltage from the power board to the lamp ballast board and got a 272v dc. Just replaced the lamp...
Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://homenol.blogspot.com/
If blinks continue without any pause, the main board is faulty.
Search the site by type in the "brand name" to your device, [Exclude the model number] in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
3answers
SprintScan 4000
paul here i am, what happened, you suddenly ended our session, do you still have the script? we can continue it there if you want. just watch out for my reply.
Samsung DLP HL-55086W lamp light flashing slowing just after replacing lamp
Problem cs pro 4000 minolta code c400
exposure lamp the brigh light under the big glass section
open the front door, look to your left small cover remove thescrew with machine on press trouble reset if the code comes back see if the web site below has the lamp and or the circuit board that controls it
Precision Roller Printer Toner Cartridges Parts and Supplies Office...
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
2helpful
Looking for service manual on maytag 4000 series 4000 front loading washer. Model # MHWE450-WOO
Sorry, this forum is not able to supply any type of manual, installation instructions, electrical or schematic diagrams direct; it's just made up of ordinary guys and gals, probably at home and from all over the world, with experience of addressing problems and giving guidance for free on the web ;-0)
You will need to type into your search engine/web browser '(make) washer manual' and you should be presented with a number of sources from which you can either download for free or have to pay a nominal amount. During the process you will be asked for the actual model number!
You could also try the manufacturer's web site direct.
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C.
5helpful
Need instruction manual
Homedics makes several units that are virtually identical to the Walgreen counterparts. Why not try the Homedics web site? It has a support section. Be sure to list your model number as there are several wrist cuff models. If the web site doesn't help, either call Homedics or try a web search by listing your model number followed by 'manual'. I would have tried to find the manual for you but I don't know the model number. Good luck.
1helpful
3answers
Cant get my computer to recognize my SprintScan 4000
The scanner uses a "twain" driver, try searching for that, it may be one of the files you already downloaded. Just look in the download u got.Also try going to add hardware, select the scanner there and poit it to the downloaded file when uit asks if you have a disk that came with it. Download the drivers to your desktop, rt click and open a folder on the desktop, and drag all of the drivers and the Twain one especially, into the folder.
No picture
My too, same problem - tried replacing lamp ($150), no luck, replaced ballast ($200) no luck, replaced power supply ($150) no luck and TSC is telling me to replace the main engine ($600) - way too much for this piece of junk (cost me $4000 in 2005) - don't buy optoma products!!!
Top Polaroid Office Equipment & Supplies Experts
Sean Wright
Sean Wright
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Are you a Polaroid Office Equipment and Supply Expert? Answer questions, earn points and help others
