After charging my Sansa the second time, I try to turn it on and get no further than the msg "Not enough space for music DB, Free 90 MB" before it automatically turns itself off. We tried to reset it, and to download firmware or updates. It won't do either of those, it just gives the same msg. When we try to delete files using the PC, the music does not show up in the files. Can you help?
SOURCE: Sansa C150 No Space for DB. Please free more than 4.0 MB
are you able to format the player while in msc mode?
right-click on it while in my computer and select the format option, make sure your selecting your mp3 as this will delete all the files off the device. It if says failed to format, try doing it thorugh disk management. To get there you can right-click on my computer and select manage from the drop down menu. From here you will see disk management on the left hand side. Then a larger rectangular box with the drive letter that represents your player, you can right click on this and select format.
Or just try a different computer, if its the same everywhere then youll probably have to end up emailing sandisk, stating everything you tried. They will probably ask you to do a couple more things, but if you keep at it, youll end up with an RMA*.
*RMA = Return Merchandice Authorization
SOURCE: sansa fuze 4GB memory is full
I had this same issue today. I actually followed someone else's post and used my computer to reformat it (right click on it in Windows Explorer, and choose Format). This worked. I just loaded it back up and am good to go. Good luck!
SOURCE: Everytime I turn on my sandisk fuze it says that
Having received no response in over a month, I assume this is no longer a problem.
SOURCE: My Sansa Fuze 8 gb will briefly power up give a
Im Having the same problem with my sandisk player 8gb. It keeps saying , Free 90 mb and then powers off. HELP !!!!!!!!!!!!!!!!!
SOURCE: My Sansa Fuze worked fine for a while.Now when I
Having received no response to my latest query in over two months, I assume this is no longer a problem.
