Plantronics Explorer 220 Bluetooth Headset Wireless Headset Logo
Posted on Mar 15, 2009
I recently purchased a new phone, cannot remember blue tooth code
I have a Plantronics blue tooth, and cannot remeber my pin code for it, Is there a generic code I can use, or do I have to buy another Blue Tooth? It is a Plantronics 220 Thanks for any help you can give.
Anonymous
Level 1:
  • Contributor 3 Answers
  • Posted on Mar 20, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
1085
Points
22
Can't remember how to pair my LG HBM-710 to my new phone - Samsung Fascinate. Can you help?
to pair a blue tooth device to a phone first you must turn the bt power on the phone to on,then you have to put your blue tooth device into discovery mode,now most manufactures use the power button for thisw feature.By holding down the power button on your device when turning it on for 6 to 10 seconds it usually puts the device into discovery mode.there should be a light that stays on on your blue tooth device.once you have the bt device into discovery mode you will be able to pair the device to your phone by search or add new device,once it pairs it will ask for a pin or pairing code.most manufactures of blue tooth devices use a 4 digit factory pin pairing code they aare as follows 0000,1234,9999,or 1111 once youve put tjhe pin code on they will pair ,i hope this helps
8helpful
2answers
How do i make my backbeat 903 discoverable
Most manufactures of blue tooth devices use the power button to turn the discovery mode on,by holding the power button down for 6 to 10 seconds when turning on your blue tooth device a solid light should come on,that means your blue tooth is in discovery mode,then what ever device you are connecting it to has to have the blue tooth power turned on,then there should be a add new or search for devices,after thatyou will need a pin pairing code,Most manufactures use a factory 4 digit pin pairing code they are as follow,0000.1234,1111 or 9999 i hope this helps
2helpful
How to get blue tooth
first turn your bt power to on in your phone menu then turn your bt device to discovery mode most devices you just hold the power button on for 6 to 10 seconds and a solid light appears once you have it in discovery mode you will have to search or add new devise from your phone,if you have everything right they will find each other but you will be asked for a pairing or pin pass code most blue tooth device manufactures use a 4 digit code they are as follows 0000,1234,9999 or 1111 i hope this helps
How to you set it up with your phone
In order to set up your blue tooth device to your phone you first must turn your blue tooth power to on in your phone menu then you must turn your blue tooth device into discovery mode.this usually is done by holding the power on for 6 to 10 seconds and a solid light will be on,then in your phone menu you can add or search for blue tooth device if you have your blue tooth in diuscovery mode the two will pair then you must enter a pin or pairing code,most manufatures of blue tooth devices use a 4 digit factory pin or pairing code they are as follows 0000,1234,9999 or 1111 enter the code and they will pair ,once paired it might ask you to connect ,selet ok or yes and your in business, i hope this helps
2helpful
2answers
I have a droid x and a friend gave me an plantronics explorer 240 cause she had gotten another one. I thanked her not thinking to ask how it worked like what buttons was what and how to connect it to my...
First of all, go into Settings and then Wireless & Network settings on your Droid X, then push Turn on Bluetooth. The check mark in the box should be green once its on. Then click Bluetooth Settings. Meanwhile, turn on your headset by sliding the power switch towards the microphone. The light should flash blue and red. Now go back to your phone and push Scan for Devices, at which point you should see something like "XXXPlantronicsHeadsetXXX". Push that, and it should work. IF it asks you for a passcode, its 0000. Here's the Plantronics help site: http://www.plantronics.com/us/common/easytopair/#/explorer-240
4helpful
How can I conect to my HTC wildfire when searching my phone cant find my plantronics Many thanks
You have to put your blue tooth device into discovery mode,Most blue tooth manufactures use the power button by holding it down for 6 to 10 seconds when turning the device on,then when you are searching they will pair ,now you will be asked for a pin or pairing code.Most blue tooth device manufactures use a factory pin pairing code they are as follows 0000,1234,1111,or 9999 i hope this helps
I do not remember the pin to my plantronics blue tooth
hi, you can pair the bluetooth device by using the pin number 0000
Aug 27, 2010 • Cell Phones
1helpful
Blue tooth will not pair with my new phone. keeps asking for a pin. i dont recall setting one up and dont have the manual anymore to remember the basic one it came with.
blue tooth will not pair with my new blackberry 8320. keeps asking for a pin. i dont recall setting one up and dont have the manual anymore to remember the basic one it came with.
6helpful
4answers
Code
the code is (0000)
hope this helps
1helpful
2answers
Blue tooth pass code
Typical pairing code for PLT Voyager 510 is 0000
Top Plantronics Radio Communications Experts
 Grubhead
Grubhead
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Plantronics Radio Communication Expert? Answer questions, earn points and help others
