Frigidaire  Electric Dryer Logo
Anonymous Posted on May 01, 2013
Electrolux I have an electrolux dry model EIED55HIWO and I recieved an E63 code. I toke the dryer apart to check heating element, element was good so I reassemble the dryer and it was not displaying error code. I started dryer, it ran for about 2-5 minutes and stopped and displayed error code e61. What is this code and why would it switch from e63 to e61.
  • Electrolux
    Electrolux May 07, 2013
    Hello again Curtis - What I meant to say was that error codes E61 and E63 could potentially mean the heater relay has short circuited or there is a wiring malfunction. When a short circuit exists, error codes can potentially switch from one to the next. In any event, I would recommend having a service technician take a look at it.
  • Official Brand Answer 4,342 Answers
  • Posted on May 03, 2013
Electrolux
Level 0:
Answers
4342
Questions
0
Helped
1467807
Points
5907
Hello Curtis - Typically, error code E61 indicates a Heater Relay failure. At first the heater was grounded, and now possibly the heater relay. When the heater grounded it could have shorted the relay as well. Generally it is a good idea to have a professional take a look at it to get to the root cause. Cost of parts and technical expertise entailed in these types of replacements can be a bit tricky.
5 Related Answers
Anonymous
  • 1314 Answers
  • Posted on Jan 24, 2008
SOURCE: Frigidaire Electric Dryer error code "dr"
try pressing options and select for ten seconds loc shouls come on then do it again to turn it off also check to see if the door is closing properly and that the door switch is closing and let me know i cant find no dr code so i dont think an error code i suspect it has something to do with the door closing
dragonsthatk
Albert Getty
  • 547 Answers
  • Posted on Jun 19, 2009
SOURCE: LEQ2152ES 2005 dryer shuts off when start us pushed
The belt can be replaced as follows.
1 remove top and front of dryer shell
2 belt goes around drum around motor pully then under tentioner wheel
3 replace front and top of dryer
(top pops off use a slotted screw driver)
Thanx for using Fixya Please take your time to rate me
Anonymous
  • 1531 Answers
  • Posted on Sep 17, 2009
SOURCE: frigidaire electric dryer aeq7000es1 low heat only code e4a store
this is a door switch issue make sure the door switch is not broken
PRIMOAPPLIAN
  • 401 Answers
  • Posted on Jan 16, 2010
SOURCE: Frigidaire Dryer not drying clothes properly
TRY DISCONECTING THE VENTING FROM THE BACK OF THE DRYER THEN RUNNING IT .POSSABLE THE OUTSIDE FLAPPER STUCK?IM THINKING NOT THE DRYER. GOOD LUCK!
If you need further help, I’m available over the phone at https://www.6ya.com/expert/dude_653d05454b389bba
Anonymous
  • 43501 Answers
  • Posted on Aug 22, 2010
SOURCE: have a frigidaire "gallery" series stackable
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
Check out this tip that will give more details…
Gas dryer not working gas dryer not heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
Check out this tip to see the things that can fail to cause your electric dryer not to work.
Dryer Troubleshooting Electric dryer wont heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
2answers
Error code e64 dryer Electrolux FFSE5115PW2
How to Fix Electrolux Dryer Error Code E64
Appliance Express https://applianceexpresstx.com > News and Tips
Apr 10, 2023 - If your Electrolux dryer is showing an E64 error code, this means there is a problem with the heating circuit. When this occurs, your dryer ...
Common Electrolux Dryer Error Codes & How to Fix Them
Just-in Time Appliance Repair https://justintimeappliance.com > blog > common-elect...
Feb 3, 2020 - Another of the more common Electrolux dryer error codes, E64 indicates a malfunction with the heater's wiring or the heating element itself.
How To Fix Frigidaire & Electrolux Dryer Error Code E63 E64
howtofixit.net https://howtofixit.net > how-to-fix-frigidaire-electrolu...
Oct 18, 2020 - These E63 or E64 error codes generally mean that you have an issue with the heating element ...
Videos for E64 Error.
2answers
I have Electrolux dryer model number EIED55HIWO and it says E64code...what do I need to do?
It indicates that there is an open it the heating circuit. It most likely means the heating element has gone out in it.
If you need further help, reach me via phone at https://www.6ya.com/expert/steven_a67ead41eb5fc62a
1helpful
Electrolux Dryer quit and has a code E 63
Mark, the heating element is underneath the drum, on the left (as facing the front of the unit).
Per the Dryer Tech Data Sheet:
E63 Error Code indicates: [Fault] Heater to Earth Ground [Possible Fault Conditions] Heating element or wiring defective [Possible Solutions] Check heater coils and connections for short circuits to the cabinet. Replace heater and/or wiring and retest.
To open the cabinet is quite difficult, speaking as a non-professional. There may be easier methods than what I used, but I was successful. First I removed all the screws from the back (there are many). This got the top and the back panels removed. The left side (where I could see the heating element was) gave me considerable trouble until I realized I had to remove the door trim to reveal one last screw. Finally got the side off and swapped out the heater. Much much vacuuming for me. I am still trying to figure out how to clean out the bottom of the duct (underneath lint filter), but that's another post.
Also, just in case you don't have the manual and/or need to order parts, I will include a link.
http://www.searspartsdirect.com/partsdirect/part-model/Electrolux-Parts/Dryer-Parts/model-EIED55HIW0/1412/0151200
For some reason, the Sears Parts Direct website lists the dryer as a Gas dryer, which it obviously isn't, as the part in question is very clearly an electric heating element. Hope this helps.
-Nick
Electrolux code e63
why was it happening
Dec 05, 2013 • Dryers
Electrolux dryer EIED55HIWO
Hello - Typically 88:88 on an Electrolux dryer indicates a generic power failure code. Try resetting the unit by unplugging it or flipping the household breaker off. Wait approximately ten minutes.
Electrolux dryer e63
Check heater coils andconnections for short circuits to the cabinet. Replace heater and/or wiring andretest.
Jul 29, 2012 • Dryers
E63 code
E63 is for a open heating circuit. could be a problem with the heating element or a sensor gone bad. Check to see if your dryer is under warranty. If it is I suggest you have the manufacturer take care of the problem. If not let me know, and we'll start by checking the heating element.
Display window says call service and a E63 code
Hi
Thanks for using FixYa. Error E63 indicates heating element or the wiring is defective. To resolve this issue you’ll have to check the heater coils and connections for short circuits to the cabinet. Replace the Heater and/or wiring and retest. Please do accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
11helpful
3answers
Electrolux dryer error code e63
I have ann E63 code on my Electrolux dryer. THe vent pipe was somewhat clogged but now is cleaned.What do I do?
7helpful
3answers
Dryer shows E63 error code? What is it? Should I call service?
The error code E63 is a high temperature warning
If you dryer is under warranty, take advantage of it. If not it may be a failing sensor or possibly a control board.
Top Frigidaire Dryers Experts
ZJ Limited
ZJ Limited
Paul Bade
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
