I got it installed it into a grandam 2003 and the green hand brake wire was left out on purpose to i could ground on the metal in the cigarette lighter (to play dvds without the handbrake on ), but when i do i get the amp grd message have no audio for tuner, visual, or dvd, i tried ground / unground but didnt do anything. any help would be appreciated.......
SOURCE: park brake switch
If you have the old firmware then all you need to do is ground the parking brake wire..
if you have the new firmware(just bought the system) a toggle switch is involved:
1 - connect e-brake wire from dvd unit to the switch
2 - connect a ground wire from switch to the unit chassis(any good metal grounding surface will do)
3 - pop in a dvd, toggle the switch back and forth 2 or 3 times depending on what wire you placed where...and voilaa!! your dvd system should work in motion!!
SOURCE: vrv785bt- No sound except tuner
Correct, I had the same problem, I assume that this would work for both the NZ709 as well as other clarion systems that only play tuner (radio) and not USB, DVD, Bluetooth, or any other audio. THis is only with an Amp installed. I followed this advice connected up the Blue Power antenna wire to the Blue White remote wire and that was it.
SOURCE: ive got my jensen vm 9512 wired in but i cannot
It's not safe to wire at the cigarette lighter you must hook it up to the handbrake but after you connect it there is a few steps to program the screen before. You can find it how to in your installation manual.
Testimonial: "sound man but listen my black wire behind my radio isnt dat strong nd ive tried wiring a switch to it so i dont have to put it to da handbrake but da switch wont work please help"
SOURCE: clarion vrx 485 vd.tuner works with amp but cant
yellow battery
red accessory
black ground
purple right rear + speaker
purple/black right rear -
green left rear +
green/black left rear -
white fr left +
white/black fr left -
grey fr right +
grey/black fr right -
blue auto antenna
blue/white rem amp
brown phone mute
orange/white illumination
grass green handbrake but if u want to play dvd's
whilst u drive connect this to earth
pls rate people arnt rating hope this helps
it sounds like you have hooked the power wires up wrong try trace back your wires with this diagram
SOURCE: when i ground my clarion vrx755vd it still says audio only
that is where its suppose to be connected it that you dont have it grounded properly
