The LG NB5530A only has a digital optical audio input. The LCD40883F1080P has a digital (S/PDIF) optical audio output above the RCA audio output jacks on the back connection panel.
Your best audio option is to use this connection. When new, the NB5530A came with a digital audio cable. Remove the protective plastic covers from the cable ends. Plug in the cable using the correct orientation on both sides. If the original optical audio cable is missing or damaged, purchase a replacement and use it. (The audio and power ports on the NB5530A can be covered by a plastic cover. Remove it if necessary and replace it.
If you want to use the analog audio output on the TV, you will need a optical digital to analog audio converter. You still have to provide the digital audio cable between the TV and the converter as well as the RCA cables. See https://www.amazon.com/Digital-Optical-Analog-audio-converter/dp/B004C4WPXA for one example.
This could possibly be an easy fix. There are a number of troubleshooting steps you can take to isolate where the problem is coming from. Sometimes its a compound problem including fuses, capacitor(s), FET's or simple cold solders on the power supply board. If you are pretty knowledgeable on electronics and testing i can give you some further testing steps. Or you can take the back of the tv and do a visual evaluation for any burns, cap leaks etc. Hope this helps, im here if you need further assistance
-Tim
Check and replace its tuner. It's faulty. Contact any service technician. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy. Surf the site with patience. http://electronicshelponline.blogspot.com/ Pull up older posts there.
How many times do this light blinks at a time of switch on? Count it. These blinks are fault indications. From these blinks, you can determine about which section inside it is faulty. It will make fault location easy. Count it, and check this site for more details about these blinking codes.
blobby 1589, my Bush freesat box has just done the same. Power going to it. Blue light on. Cannnot turn the box on. Screen froze before it turned off. Tried unplugging it. There was a software upgrade 2 days ago - wonder if that has anything to do with it
only virgin media tivo box
