Question about Faberware Coffee Makers & Espresso Machines
Lost the users manual for the Farberware 155 Automatic Perculator
What I really need to know is the coffee measurements. Within the manual the coffee measurements are broken down. I have the 55 cup model. (Farberware 155 Automatic Perculator)
Thanks
    Scholar:
  • 176 Answers
Hi. 3 scoops of coffee to 3 cups, Them adjust from there, bobbyone
Posted on Aug 11, 2010
SOURCE:
Need a new dome lid
Go to Goodmens.com. Farberweare parts. Good luck. Ron
Sep 15, 2012 | Faberware 12-55 Cup Coffee Urn
I like relatively strong coffee. How much coffee should I put in my Farberware pot for 24 people? I am leaving in 20 minutes!
Farberware manuals do not seem to be available online. Try contacting Farberware Customer Service at the following site:
http://www.farberware.com/customerservice.html?hm=Y&ct=N&anw=N
For electric kettles try the e-mail address for Electric Appliances. Send your model number with your request for a manual.
Sorry some one was not able to respond within 20 minutes but I think this had to do with lack of a ready source for the directions for use.
Thank you for using FixYa!
Aug 12, 2011 | Faberware Farberware FSU236 12-36 Cup Urn...
Need to know how much coffee to use in Farberware auto percolator
For coffee makers try the e-mail address for Electric appliances. Send your model number with your request for a manual.
Thank you for using FiXYa!
Jul 29, 2011 | Farberware FSU236 36Cup Coffee Maker
Where can I get a users manual for Farberware coffeemaker FSU122?
Jul 24, 2011 | Faberware FSU122 Coffee Maker
What makes a perculator heat?
Hi, If you have a Farberware, Just look into the bottom of the pot. There you will see what looks like a hole in the pot. That is the high heating element, under the pot, when you go to make coffee the pump ( rod) sits into the hole. When you turn it on to make coffee the high heating element that the pump is in gets very hot and starts pushing the water that is in the hole to the top (that is called perking) the hot water goes over the the top and the drops into the coffee, This keeps going on until the thermostat feels it has reached 190 degrees or close to it and turns the high element off. While this is running it's cycle the keep warn is on helping the water to get hot, when the main element is off the keep warm element that runs around the bottom of the pot stays on all the time the pot is plugged in. Should the coffee get to cold the thermostat will turn the main heating element back on until it is back to 190. This system was developed by Farberware and a lot of makers copied it, But Farberware sold the pots and was known for a FAST and HOT cup of coffee. Farberware started making them in China and the pots are having a hard time keeping it up to American standers, and parts are very scarce.Farberware USA pots have been around a long,long time and are still going strong . I hope this helped you to understand how the pot works.
Dec 09, 2010 | Faberware 12-55 Cup Coffee Urn
Farberware superfast perculator
Thanks for letting us know that there was no solution other than one I would have to come up with entirely on my own. My dad who is old school wouldn't let me give up so we took the thing apart and it was an easy fix. Take the 5/16 nut off the bottom. Pull the slide pins off the thermostat. Take the philips screw out of the support holding the thermostat in place. Use a sharp pointed knife and with the silver Aluminum cap flat on the bench, make a slice on one edge. Use the knife to pull the edge away from the plastic housing and the cap will pop off. Be careful not to loose the small piece of ceramic that lies in a small whole on top of the contact. Use a sharp knife to clean the contacts and check with an ohms meter or continuity light. If it makes a good contact, put it back together. It took my dad and me about 10 minutes to do the entire job. We looked for a part for 20 minutes. Good luck. Rick and Adam Schmitt of Maryland.
Dec 08, 2007 | Coffee Makers & Espresso Machines
Coffee Makers & Espresso Machines Logo
1,124 people viewed this question
Top Faberware Coffee Makers & Espresso Machines Experts
Bob Janelli
Level 1 Expert
ray gallant
ray gallant
Andrew Taylor
Andrew Taylor
Are you a Faberware Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
