Canon FS100 Digital Camera Logo
Posted on Mar 15, 2009
Download to mac from canon fs10
I was told i needed imovie 08 now i have it,  and still can't get movies off of canon fs10 to my mac
Anonymous
Level 1:
New Friend:
  • Contributor 3 Answers
  • Posted on Nov 12, 2009
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
596
Points
Hi I have had the same issue I found this MOD converter and it has worked for me.
http://www.my-video-converter.com/mod_converter_mac/
It does cost $29 but you can trial before you buy.
GOOD LUCK :)
Can not transfer videos from Canon VIXIA HF R30 to Mac
As to the wi-fi and ftp solutions, I have no clue, nor do their customer service people. The keep saying, "Well, I have no no experience with a Mac, but on Windows. . . " Worthless! But maybe you'll have better luck. 1-800-828-4040.
As to the USB problem, that's not too bad. The Power Charger MUST be plugged in to transfer any files anywhere! The movies and photos are importable to iMovie11. Select the playback button on the left side of the camcorder (bottom button on right). Select the Index selection button in the upper left corner (the icon with rotation arrows). Select either the internal memory or the SD icon, if you've inserted your own chip. Then select AVCHD movies. Attach the USB cable to the camcorder and your Mac. When the next window says "Select the memory for connection," select "All (for PC only)". Thumbnails will quickly be created for all movies. A "Canon" disk icon will then appear on your Mac's desktop. Launch iMovie11. IMovie will then detect the camcorder. (If it doesn't work the first time, then quit iMovie and open it a second time.) There will be three options in the pop-up menu on the bottom left of the camera import window (camera import auto-launched when a connection is detected): one for mp4 movies and one for AVCHD movies (and one for your iSight, built-in camera for recording). Importing is then just a question of clicking which movie clips you want to import from which source and clicking the "Import checked..." button.
MP4 movies (only) can also be downloaded directly to your hard drive by opening the Canon disk icon>DCIM folder>###CANON folder>selecting anything ending in ".mp4". The jpg thumbnails are not needed. Retitle the movies as you so choose in the finder after putting them somewhere on your hard drive.
I've opened the info window on an(y) mp4 movie, selected "Open With...">QuickTime Player, then checked "Change all" so that all mp4 movies open with QuickTime rather than iTunes, the default. Those movies can also be imported later to iMovie using FIle>Import>Movies and finding the files on your hard drive.
If anyone comes up with what the heck you need to do to use Mac's built-in ftp server and what to type into the camcorder's destination folder windows for wi-fi downloading, PLEEEEEEEEEEASE let us all know!!!!! (Not that the USB connection isn't sufficient.)
tip
Flawlessly solve questions-Canon HG20 MTS to iMovie 9 with retain best quality
Flawlessly 1080/60i MOV for iMovie-Converting Canon HG20 MTS files to AIC MOV for iMovie
I have a Canon HG 20 with an internal 60GB hard drive. I am using the Mac OS X 10.6 Snow Leopard and iMovie 09. The apple website says that this camera is compatible with iMovie and even sells it on it's website. When I open iMovie and import the .mts files to iMovie, it prompt an error. After google search, found if I want to edit Canon HG20 1080/60i .mts video with high quality for iMovie 9 on Mac, must to convert Canon HG20 1080/60i .mts files to MOV for iMovie 9 before editing.
And as we konw, Apple Intermediate codec is one of the apple built-in codecs, while others could be Apple DV/DVCPRO - NTSC, DVCPRO50 - NTSC.So convert hg20 mts to aic mov is the best choose. Therefore i need mts to aic converter. Aunsoft Final Mate for Mac is the recommended camcorder software to convert AVCHD to apple compatible formats.
Here is the step-by-step guide to quickly convert Canon HG20 MTS to Apple Intermediate Codec 1080/60i (*.mov) with highest quality for editing in iMovie 9 on Mac.
Step 1. Directly download 24Mbps .mts files from Canon VIXIA HG20 to Aunsoft Final Mate for Mac.
Turn on Canon HG20 camcorder and connect it to computer via USB cable, then launch Aunsoft Final Mate for Mac from Application folder. With built-in wizard, you can easily to capture Full HD .mts files from Canon HG20 camcorder to the program. Select "Import" instead of Backup to quickly capture videos from camcorder. You can find imported videos under "Camcorder Tab" in the main interface of Final Mate for Mac.
Step 2. Create a Movie for Converting Canon VIXIA HG20 MTS files to AIC MOV.
Just select one or multiple video files you would like to convert and then drag and drop them to Movie tab. In this way, a Movie for conversion will be created.
Step 3. Export AIC MOV video file.
Click the Export button and choose iMovie and Final Cut Express > Apple Intermediate Codec (AIC) (*.mov) to choose export format for further editing in iMovie. In this way, all video clips will be merged as one single movie for convert to iMovie.
Tips: You are free to set/adjust output MOV files parameters (Bit rate - high quailty, Frame rate - 60, Resolution/Size - 1920 x 1080, channel - 5.1 channel) to make a good output quality. With this set you can get a Flawlessly 1080/60i MOV for iMovie.
Step 4. Click OK to start converting.
Click "OK" to start converting Canon HG20 MTS files to AIC MOV for iMovie .When the conversion is finished, you can import converted mov to iMovie without rendering and edit high quality videos from Canon Vixia HG20 24Mbps mts on iMovie Mac.
Tips: The Canon VIXIA HG20 boasts 1920 x 1080 Full HD, and has a CODEC capable of recording 24Mbps -- the highest AVCHD bitrate --through Canon's own Full HD CMOS Image Sensor and advanced DIGIC DV II image processor. Final Mate for Mac also can lossless split/cut and join/merge Canon HG20 Full HD MTS on Mac with no compression.
tip
Mac Canon DSLR Video Converter-Transcode Canon EOS 5D H.264 MOV to iMovie on Mac
Converting Canon 5D Mark II Videos to iMovie 8/9 on Mac with Best Quality <br /><br /><b>Mac DSLR Video Converter</b> functions as the <b>Mac Canon DSLR video converter</b>, Mac Sony DSLR video converter, Mac Panasonic DSLR video converter, Mac Nikon DSLR video converter, Mac Kodak video converter, Mac Flip video converter and even Mac iPhone 4 video converter for your Apple computer with PowerPC or Intel CPU. <br /><br /><b>Mac DSLR Video Converter</b> enables you to <b>import H.264 MOV videos from Digital SLR cameras</b> to editing software like iMovie 8/9/11,Final Cut Express,Final Cut Pro,Final Cut Studio,Adobe Premiere Pro,Avid etc. <br /><br /><b>Mac DSLR Video Converter</b> helps you organize DSLR recordings from camcorders like Sony VG10, Canon 600D in AVCHD MTS/M2TS, MOV formats, and <b>convert MTS/M2TS and H.264 MOV to Mac</b> editable format. <br /><br />Below is the quick guide for you to <b><a href="http://www.aunsoft.com/video-converter-mac/">convert Canon 5D Mark II videos to iMovie</a></b> with Aunsoft Video Converter for Mac OS X like Snow Leopard, Leopard and Tiger. <br /><br />Step 1. Import Canon DSLR MOV to Aunsoft Video Converter for Mac. <br />After the movie clips are transferred to Apple computer hard drive, run Aunsoft Video Converter for Mac as the best <b><a href="http://canon-videoconverter.com/2011/06/mac-canon-dslr-video-converter-transcodingconverting-canon-eos-5d-mark-ii-h-264-mov-to-imovie-on-mac/">Mac Canon DSLR Video converter</a></b>. Click the "Add" button to browse the Canon DSLR .mov files for conversion. <br /><br />Step 2. Choose QuickTime MOV format. <br />Click the "Format" option and navigate the mouse cursor to Common Video &gt; MOV - QuickTime(*.mov) as output format. The Mac DSLR movie converter will <b><a href="http://www.aunsoft.com/video-converter-mac/">transcode Canon H.264 videos to iMovie</a></b> supported videos with original resolution in 1920x1080. <br /><br />To change video frame rate, just click the "Settings" button and choose the frame rate option. <br /><br />Step 3. Convert Canon DSLR EOS MOV for iMovie. <br />Click the convert button under the preview window, and the Mac Canon DSLR movie converter will start <b><a href="http://www.aunsoft.com/video-converter-mac/">converting Canon H.264 MOV to QuickTime MOV</a></b> for editing in iMovie with high quality. <br /><br />After the conversion, just import the output videos to iMovie 8, iMovie 9 or even iMovie 11 for creating your own movies.
Canon FS200 camcorder: can I download to a mac? If not, what wou
yes, it does.
It only works with iLife 08 or 09, not older version.
It's easier to connect with a card reader to your Mac, Open iMovie to import. If via Camcorder, make sure Camcorder is set to display->Print/PC.
Mac G4 won't recognize Canon FS10 video output
This is only a suggestion: If you want to use the software that comes with the camera, PIXELA ImageMixer 3 SE, this needs to be installed first. Also make sure the camcorder is set on Play mode and that you have chosen which memory you want to transfer data from.
Alternatively, you can transfer the movies through iMovie, which is usually the easiest way. If you are not familiar with transfering and editing movie clips, I would recommend this.
Apart from this, as always, I referr to the user manual. Good luck!
tip
Convert and Edit Canon VIXIA HF200/HV30/HF R11 to iMovie, iMovie? 09, iMovie? 11
"Vixia HV30 HDV camera help! Mac and iMovie? I cant get my vixia HD30 HDV canon camera to import any video to my iMovie. ive set the video type to HD-1080i-30 but still nothing. any ideas on how to fix this?"
"I cannot get my mac to recognize my new Canon Vixia hf200 video camera. How do I get it to import my videos? I have a mac tiger, 10.4. My imovie is '07. The Canon is HD and connects through USB."
As Canon VIXIA HF series camcorders becoming more and more popular among people, you may have problem of uploading Canon VIXIA HF video to iMovie, or Mac. Because some of Canon VIXIA camcorders cannot be compatible with iMovie, iMovie' 08, iMovie' 09, such as Canon VIXIA HF200, VIXIA HV30, VIXIA HFS100, etc. Or even though Canon VIXIA camcorders can be compatible with iMovie or Mac, but sometimes video off Canon VIXIA series is not recognized by iMovie due to different aspect ratio or video codec.
If you cannot import Canon VIXIA video like Canon VIXIA HV30, VIXIA HF200, VIXIA HF S100, etc to iMovie for editing, you need a powerful Canon VIXIA to iMovie Converter to convert Canon VIXIA AVCHD video to MOV, MP4, DV for iMovie firstly, then you can import them to iMovie to share or edit.
Doremisoft Canon VIXIA to iMovie Converter is designed for Mac users to convert camcorder video like AVCHD MTS/M2TS to MOV, MP4, DV for iMovie and Mac. It also support converting video such as MOD, TOD, MKV, etc to Mac, iPad, iPod, iPhone, PSP, Blackberry, iDVD , FCP, FCE, etc.
But how to transfer Canon VIXIA video to iMovie? Here, quick guide for you to follow to convert Canon AVCHD MTS, M2TS files to iMovie step by step:
Step1: Install and Launch Doremisoft AVCHD Converter for Mac
Step2: Import Canon VIXIA Video
Click "Add File" to input your Canon VIXIA AVCHD MTS files to Mac AVCHD Video Converter. You can upload several videos one time.
Step3: Set Output Video Format for iMovie
Click "Profile" to open the Profile drop-up list to select MOV, MP4 or DV as output video format for iMovie.
Step4: Convert Canon VIXIA Video to iMovie
Click "Start" button to convert Canon VIXIA AVCHD files to iMovie. After conversion finished, you can edit your converted Canon VIXIA videos with iMovie as you like.
Related: How to Get AVCHD MTS/M2TS, MOD Files off HD Camcorder to Mac, iMovie, FCP?
How to Convert and Import Sony HDR Series Video to Mac, iMovie?
on Nov 09, 2010 • Computers & Internet
tip
Best HD Camcorder for Mac, iMovie, iMovie? 08, iMovie? 09
Recording daily life and interesting things with a HD camcorder becomes a trend for our people. They like to share these digital camcorder videos on Mac or PC with family and friends. However, selecting a good digital camcorder for Mac is not easy for green hand. Maybe more tips need paying attention, for example, the types of your camcorder and Mac, the version of iMovie on Mac, Mac and PC compability with digital camcorder and so on.
iMovie has been a Mac OS X only application bundled in the iLife suite of Macintosh applications since iMovie3. From 2007 to 2010, Apple developed iMovie to iMovie' 08, iMovie' 09, and iMovie for iPhone and iPod Touch. Luckily, iMovie' 08, iMovie' 09 are designed to work with a wide range of digital video devices and formats, including tape-based(use a FireWire cable, also known as IEEE 1394 or i.Link) and the latest tapeless camcorders that record to flash memory, a hard disk drive(HDD), or DVD media.
A list of Digital Camcorders Compatible with iMovie' 08, iMovie' 09 on Mac OS X
NTSC Camcorders(a video format used in North America, Central America, Japan, and parts of South America)
Canon: DC20, DC50, DC220, DC230, FS10, FS11, FS100, HF10, HF11, HF100, HG10, HG20, HG21, HR10.
JVC: GZ-HD10, GZ-HD30, GZ-HD40, GZ-MG330, GZ-MG67, GZ-MG255, GZ-MG555U, GZ-MG505U.
Panasonic: HDC-DX1, HDC-SD5, HDC-SD9, HDC-SD20, HDC-SD200, HDC-HS9, HDC-HS20, HDC-HS100, HDC-HS200, HDC-HS300, HDC-SX5, SDR-H50, SDR-H60, SDR-H200, SDR-S10
Sony: HDR-CX11, HDR-CX12, HDR-SR1, HDR-SR7, HDR-SR11, HDR-TG1, DCR-SR82, DCR-SR200, DCR-DVD308, DCR-DVD508, DCR-DVD403.
PAL Camcorders(a video format used in Europe, Africa, the Middle East, most of Asia, and parts of South America)
Canon: DC50E, DC220E, DC330E, FS10E, FS100E, HF11E, HF100E, HG10E, HG20E, HG21E.
JVC: GZ-HD10KR, GZ-HD30, GZ-HD40, GZ-MG255, GZ-MG67, GZ-MG155, GZ-MG330.
Panasonic: HDC-DX1, HDC-SD9, HDC-SD200, HDC-TM20, HDC-TM300, HDC-HS20, HDC-HS200, HDC-HS300, SDR-H79, SDR-H60, SDR-S15, SDR-S26.
Sony: DCR-DVD908E, HDR-CX11E, HDR-CX12, HDR-SR1E, DCR-SR5E, HDR-SR12E, HDR-TG1E, HDR-CX7E, HDR-UX20E, DCR-SR82E, DCR-SR100E, DCR-SR300E.
Although iMovie' 08, iMovie' 09 on Mac OS work with most of HD digital camcorders using MPEG-2 (standard definition), MPEG-4, AVCHD, and H.264 formats, not all tapeless camcorders are compatible with iMovie' 08, iMovie '09 because of the wide range of media types and the different ways manufacturers store video on these media types.
How to fix it? To meet people editing AVCHD, MOD files with iMovie, enjoying HD camcorder video on Mac, a powerful HD Video Converter for Mac is specially designed for people who need to convert AVCHD MTS/M2TS, MOD, TS, TOD, MKV files to iMovie MP4, MOV, DV for better editing. Besides, that Mac HD Converter is also the very choice to convert HD video like TP, TRP, M5S, TOD, MPEG2 HD, MPEG4 HD, MOV HD, WMV HD, AVI HD to Mac application: iTunes, iDVD, FCP, FCE, etc.
Related: Click here to see more info of AVCHD Converter for Mac for people to convert AVCHD files to Mac iMovie, iPod, iPad, iPhones, PSP, BlackBerry, Zune and other handy device.
How to Convert AVCHD MTS/M2TS to Mac formats?
on Sep 21, 2010 • Computers & Internet
13helpful
3answers
Can't transfer videos from JVC Everio camcorder onto my MAC
Share: How to import .tod files from JVC Everio HDD Camcorder to iMovie?
Requirements: iMovie (Part of the iLife 08 package)
Step 1: Connect the Everio to the Mac (Via USB)
Make sure you are powering the Everio from the mains before connecting your JVC Everio Camcorder.
Step 2: Playback on PC
Select “Playback on PC” on the Everio, once connected you will see the Everio HDD symbol appear on the desktop. The video files on the Everio are stored in the SD Folder/PRG***/MOV***.MOD.
Step 3: Open iMovie
Once you open iMovie, you will see that it recognizes the Everio straight away and will attempt to import your video.
You are now ready to use iMovie to edit your video files.
If need change .tod files to common video formats like mov, mp4, m4v, mpg, mpeg, dv, flv, avi, wmv, 3gp, mkv, mp3, aac, wma, m4a, etc. Mod Tod Video Converter for Mac is a good choice. The program can also convert mod tod to ipod, mod tod to iphone, tod to apple tv, tod to blackberry and more devices!
2answers
Connecting the Canon FS 100 to my iMac
jhobby2000 buy a usb 2.0 specially for SD or SDHC chip
Top Canon Cameras Experts
old marine
old marine
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Canon Camera Expert? Answer questions, earn points and help others
