Nixon Esquire Dial / Band Watch for Men Logo
Posted on Mar 15, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My Esquire watch doesnt work anymore
I had the battery replaced
the warranty is up
they said it needs a cleaning it will cost me $85
Can i clean it my self
Arturs Kalnins
Level 3:
  • Master 2,338 Answers
  • Posted on Mar 15, 2009
Arturs Kalnins
Master
Level 3:
Answers
2338
Questions
9
Helped
1813031
Points
13579
Open the watch and get the battery out. Take a watchmakers screwdriver or hardened steel pin and clean (scrape) all battery related contacts till they are clean and shiny. Use dust blower to get rid of any scrape-offs. Replace the battery and contact.
If all this do not work, then you will have no option, but to bring the watch in for repair (professional cleaning).
Rate me, please.
The digital mechanism is dead.
t sounds like the digital display of your watch stopped working after a watchmaker replaced the normal battery and accidentally cut the cable connected to the rechargeable battery. To address this issue, you may need to take the following steps:
  1. Return to the Watchmaker: First, I would recommend returning to the watchmaker who performed the battery replacement and inform them about the issue. They should take responsibility for any damage caused during the battery replacement and rectify the problem.
  2. Check Warranty: If your watch is under warranty, contact the manufacturer or authorized service center to have the issue resolved. Cutting the cable during a battery replacement should not happen with a professional service and might be covered under warranty.
  3. Request a Repair or Replacement: If neither of the above options is viable, you may need to seek a watch repair specialist or a technician who can examine the watch's internal components and assess the damage. They can either repair the cut cable or replace the damaged digital mechanism.
  4. Be Prepared for Costs: Depending on the extent of the damage and the watch's value, repairing or replacing the digital mechanism may come with associated costs. Be sure to ask for an estimate before proceeding with any repairs.
It's essential to keep all communication and records related to the battery replacement and subsequent damage to ensure a smooth resolution of the issue. Ultimately, it's the responsibility of the watchmaker to address and rectify any damage that occurred during the battery replacement process.
Oct 01, 2023 • The Watches
What size of battery does a Nixon The Esquire use
A jeweler will be able to get the right size in there. Most jewelers will do it for the cost of the battery.
2answers
My kenneth cole KC2555 watch doesnt give the correct time even after adjusting it. How can i fix it?
If it's more than a year old it may need a fresh battery. Any watch or jewelry shop can do that for you for about $8.
Watch repair
RECOMENDATION:
Seek professional help.
GOTO
http://www.watch-clock-makers.org/
Hope this tip helps.
r/ David
http://antiqueclock.clockstop.com/
I need a new watch band for my Nixon Scout watch
Try contacting a Nixon service center.
You can locate your nearest service center by going to their web site "www.nixonnow.com/dealers/" and filling in your details.
Mar 02, 2010 • Watches
Watch has new battery but suddenly stopped.
Might need cleaning, oiling or other servicing ...
What do you think?
Thanks for your interest in FixYa.com
Bezel won't ratchet anymore. Perfectly smooth
If this is stuck and just wont turn that means its full of yuk and muck and just needs cleaned ou, take to a good jeweler who can clean under the bezel...if it turns but simply doesnt click that means that the click spring mechanism is broken and would have to be sent to Luminox for repair...good luck :)
1helpful
2answers
How do I change the battery?
Someone posted a link on how to change the batter on an F11. If it's not longer under warranty or you just don't want to bother with sending it back and the extra costs, you could follow this: http://timlaqua.com/2008/09/how-to-replace-the-battery-in-a-polar-f11-heart-rate-monitor-hrm/
Divers watch needs refurbished & repair.
http://service.movadogroup.com/pages.cfm?pid=4CD4575A-AB5B-AB72-9CDA4CE49DDD9176
This is a link to the Movado Group service centers, they make ESQ watches. It appears your watch has had water seep inside the case. It could be the seals around the caseback or crown. Whether repair is worth it, is up to you. I have had Casio dive watches I have sent into repair because I liked them, not for the value of the watch. In general ESQ makes a nice watch and if you like it, why not see what repair would cost. However, if this is a moisture problem, more than just visible corrosion has probably occured and the movement could compromised, if that is the case the costs of repair might outweigh just purchasing another watch. Good luck and I hope you found this helpful,
Top Nixon Watches Experts
ZJ Limited
ZJ Limited
john h
Are you a Nixon Watch Expert? Answer questions, earn points and help others
