You can unlock your HTC Wildfire by IMEI.
Find the phone's IMEI by dialling *#06# and read it from your phone screen. The IMEI code is also printed on the label in the battery compartment.
Buy an unlock code for your HTC Wildfire from a trusted and safe HTC unlock service. I warmly recommend this one because they have the best prices and great experience in unlocking.
You'll have the code in just a few minutes after you order. Insert different network sim card. It will ask you for the unlock code. Enter the unlock code and your HTC Wildfire will be unlocked and able to accept any GSM Sim card. Good luck!
http://www.htcimeiunlock.com/htc-wildfire-unlock
Testimonial: "There is no sim card slot on the phone. I guess it is unlocked. I cannot find a carrier who will activate it."
SOURCE: Hi, Can anybody help me unlocking my HTC Wildfire?
Yes you can get the unlock code through online..........i will suggest the website http://www.unlock-zone.com/ which is doing good service .....you can approach this website.
This site is nearly perfect and they were recommended highly in the cell phone forums. I used them to unlock my cell phone. contacted them and within 30 mins i had my unlock code and my phone was unlocked.
Hope this helps.
SOURCE: unlocking my htc wildfire a3333
As you have not specified in particular what is the unlock code required for you, i am giving the ways to unlock all the codes
NETWORK UNLOCK CODE:
You can unlock it by flashing your mobile if your mobile is a CDMA mobile...
The procedure for flashing your mobile is in the link below
http://hubpages.com/hub/How-to-Flash-your-cell-phone
It has an video explanation.
If your mobile is not an CDMA mobile , you can get the network unlock code(NUC) by just contacting the current network provider customer care department.It is free of cost.
The restriction code can be got from your old service provider..This restriction code is kept to prevent someone who stole the mobile from using it with another provider...
They will have a security check done with your date of birth etc..to verify whether you are the exact owner of the phone..
After that they will provide you the restriction code to unlock it and use it with another service provider..
It is all free of cost do not pay anyone for this seeing some advertisement over internet . That is all fake ads.
The above procedure works and you can verify that by seeing the rating of an happy customer here..
http://www.fixya.com/support/t4979448-need_unlock_motorola_razor_v3_from_optus
PUK CODE:
PUK code can be given only by your service provider which is specific for each and every mobile number.
Contact your sim customer care department over phone. Its free of cost to get the pin or puk no. If you cant contact through your phone get some other phone and contact them.
Go to the nearest service outlet of your service provider they can also help you.
There is no other go than the above procedure only your service provider can give it nobody else in this world nor any software.
Go to the below link and you can confirm that the above procedure works and there is a testimonial given by the customer too. http://www.fixya.com/support/t3079596-sking_puk_code
PIN CODE:
HI If you are asking for pin contact your service provider , he will give you a default pin .
If you try pin more than few predefined no of times your phone will ask PUK code which can also be given only by your service provider which is specific for each and every mobile number . Do not try PUK(new pin code) code many times or else your sim will be blocked and you will need a new sim.
SECURITY CODE:
If it is lost nothing can be done. You need to flash your mobile at an authorized service center which will reset the mobile memory and also all the data inside the mobile will be lost.
A helpful rating and an testimonial would be greatly appreciated if you are satisfied with the solution i have posted.
SOURCE: unlocking a htc wildfire
Get the Unlock code from the site
Mobile-unlocker.com/htc-wildfire/rs2wp9/ and unlock HTC WILDFIRE.
SOURCE: unlocking code htc wildfire
aliyan cheema: is IMSI 310008086996779 the IMEI? If it is, can you please post my unlock code? Much appreciated...
