Key led flashing. does this mean its locked. manual says use the scurity key to unlock. what is the security key
SOURCE: door lock led flashing plus
This is an error code, to know what the error is, you need to provide more information. Make and model of the unit and which lights are flashing.
Sgt 48
SOURCE: Kia Spectra problem with door locks
I had the same problem with my kia and they just fixed it. It was a bad switch.
SOURCE: LED lights for locking and unlocking flash at the same
that system is part of D.A.S. 2( driver authorization system verson 2). the lights in the mirror will blink red when lock and green when unlock. during the self diagnoses portion they will blink simutanilusly when the remote key batteries are low and alternating when there is a malfunction with the key or other part of the driver authorization. it sounds like your remote key central locking batteries are low.
SOURCE: 95 Toyota Camery, The car remote locks and
if the light is flashing and the central locking works then its all good the speaker wire has maybe broken inside plastic casing but hey if it all works with out the noise then leave it
SOURCE: 1997 Maxima : keyless entry will not lock or
Replace the battery in the remote. I have a feeling that it needs to be replaced, after replacing the battery, hold the lock and unlock buttons down for about 7-30 seconds for the remote to understand that it needs to pair with the car. The locks should lock, unlock then lock again.
