The tv was intermittently shutting off and on by itself then one day i get the 2 x Power 3 x OPC blinking lights, which as I believe is indicating that the IC2002 chip on the Main Board isn't detecting the 10v necessary in order to initiate the TV startup procedure, so with that in mind I've changed the Power board and "sub power board" with working ones, my problem now is that the next step requires you to enter service mode in order to do a reset so the new parts can be used but I'm not able to get into service mode, regardless of how many times I repeat the (correct) procedure, does this mean I have to replace the main board too?
