Question about Jamo SUB 250 Subwoofer
Jamo sub 250
Not switching on
  • Jamo Master
  • 18,060 Answers
Internal power? Check fuses. No fuses? Disassemble and check Power supply if it is internal. If it is external, check power supply with meter.;.
Posted on May 13, 2013
SOURCE:
  • 238 Answers
SOURCE: Jamo 250
hi, there must be this LINE IN socket (ur so called Hole), then on the onkyo, there must be this sub-line out socket, plug one end of the RC socket to the sub out of onkyo , and other to the line in of the sub, its all to do wirth its appropriate inputs and outputs,let me know
Posted on Jan 12, 2008
  • 127 Answers
SOURCE: I have bought JAMO sub 250 subwoofer and Pioneer
You don't need such cable, although you can use it if you have one. If receiver has only mono SUB output (as majority of receivers have), you just connect it to the Left socket on the Sub and it will work.
Using the Y cable would probably cause that you will fed the same signal to both left and right sockets, but half the intensity (you would divide the output from receiver by 2). So in the end the Sub would receive exactly the same signal as when using normal straight cable.
Posted on Mar 03, 2010
  • 127 Answers
SOURCE: cant connect jamo sub 250 to marantz SR4001
Use the PRE-OUT SW (subwoofer) output and connect it to the left RCA socket of your subwoofer.
  • 137 Answers
SOURCE: Jamo Sub with no power
THE IS A FUSE INSIDE THE UNIT,YOU MAY WANT TO CHECK THAT.IF IT BLOWS AGAIN WHEN TURNED ON YOU HAVE SHORTED MOSFETS. THEY ARE LIKE TRANSISTORS.
Posted on Apr 20, 2010
  • 357 Answers
SOURCE: i want jamo sub 1810 circut diagram
Check out this link:
http://2getdtv.com/directv/stereo_receiver_codes.html?phpMyAdmin=ed9585cdc5a4551847999cb4dbcce76a
Posted on Feb 25, 2012
My Jamo sub 250, the R30 was blown. May I know the value of this resistor ? Anyone can help ?
If its still is defective in a corner or in the attic? Maybe you can make info by a KLIPSCH service centre because Klipsch is the owner of JAMO http://www.jamo.com/about/ if you have not find the answer.
Jamo About
Sep 04, 2015 | Jamo Audio Players & Recorders
I have a jamo 200 sub and jamo s602 speaker how do i wire so i can listen to music from my ipad to the speakers
the easiest solution is to get yourself a cord that switches from headphone plug to RCA and connect it that way. I sure hope that this helps you in hooking your ipad up to the Jamo 200 Sub. Thanks, Cody
Sep 13, 2012 | Jamo SUB 200 Subwoofer
I have bought JAMO sub 250 subwoofer and Pioneer VSX919AH-K amp. Please advise how can I connect them. The amp has one RCA out for sub but the sub has two line in sockets (left and right). Do I need to use...
Dec 30, 2009 | Jamo SUB 250 Subwoofer
Cant connect jamo sub 250 to marantz SR4001... how do i do it? any suggestions?
Sep 27, 2009 | Jamo SUB 250 Subwoofer
I have a jamo 250 sub and dont know which coax input to use
one will do just fine if you've tried one and its not working try to refer to manual on how to set up in the receiver function menus and if the sub is powered by an external amp which most are
Jul 03, 2009 | Jamo DVR-50 System
Jamo 250
Jan 11, 2008 | Jamo D 4SUB Subwoofer
Jamo SUB 250 Subwoofer Logo
311 people viewed this question
Top Jamo Audio Players & Recorders Experts
 Grubhead
Grubhead
rjivaro
Robert Rankin
Are you a Jamo Audio Player and Recorder Expert? Answer questions, earn points and help others
