Symphonic WF20D4 TV Logo
Posted on Mar 14, 2009
Unable to program my Time Warner Cable remote to Symphonic TV
TV / DVD - Symphonic Model # WF20D4
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Jan 10, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
1079
Points
The instructions are on the back of the remote. if lost. you have to:
1) Turn tv on ( i would suggest turning it off then on)
2) Press the Device you want to sync (tv)
3) Press and hold the setup button it will blink once...let it blink twice before you go to the next step.
4) press 9-9-1
5) press the power key on the remote
6) press the channel up (CH +) button repeatedly until the device (tv) turns off.
7) when it cuts off immedieately press the setup button.
I need remote control codes for my symphonic model WF24T5 to use my dishnet remote please
Use the remote dishnet to automatically detect your code for the tv. Most of the time the procedure is on the remote.
2answers
I have Time Warner cable. I have a Symphonic SR90VE vcr/dvd that I have hooked up to the main TV. The cable box services a second tv in another room. I can't seem to get the main tv and the vcr/dvd player...
Cable goes to vcr cable INPUT, then run cables from vcr OUPUT to tv INPUT or AV.
Then put tv on input or av channel or channel 4 and use put the vcr on the channel you want to record.
Can't get to video mode
get a programable remote and program it and hit the video button
6helpful
2answers
Need codes for olevia tv
Olevia TV Remote Control Codes #tbltrouble TD { BORDER-BOTTOM: #cccccc 1px dotted; PADDING-LEFT: 2px }
Remote manufactures and service providers continuously add support for new TV products. If you have the following Satellite or Cable Systems, try these remote codes for all 2 Series, 3 Series, 4 Series, 5 Series, and 7 Series Olevia HDTVs.
Also available is the Olevia Universal Learning Remote RC-LRN that offers component programming of most video hardware including your Cable or Satellite Receivers, VCR's, Tivo's, DVD, Blue-Ray™ or even HD- DVD players.
The learning remote is available, please call at 866-965-3842
Satellite TV Systems Dish Network Remote Codes 506 or 127 Direct TV Remote Codes 506 or 127 Direct TV (Remote Model RC-64RB) Remote Codes 11144, 11240, 11331, or 11610 Cable TV Systems Cable Vision Remote Codes 506 Charter (Moxie Box) Remote Codes 1144 or 1178 Comcast Remote Codes 11144, 11240, 11331, 21075, 10159, 10154, or 10088 Cox (Remote Model UEI M720p01) Remote Codes 1610 Brighthouse (Remote “UEI” URC-11055) Remote Codes 1610, 1144, 1240, or 1331 Time Warner (Remote “UEI” URC-11055) Remote Codes 1610, 1144, 1240, or 1331 Time Warner (Remote "UEI" UR5L-8500L) Remote Code 432 Time Warner (Atlas OCAP 5) Remote Code 1610
5helpful
I have a WF20D4 TV and a comcast universal remote. I can not find the code that turns my tv on and controls volume for my comcast remote. I lost the TV remote.
0180, 0171, 0000 if your remote has a GREY ok/select button on it,
20675, 20821, 20000, 20593, 21593 if your remote has a RED ok/select button on it
Cannot program Cable remote to control panasonic 26'' LCD
the issue is with time warner remote. contact the cable company.
1helpful
4answers
How to connect a Time warner cable remote to the tv
I made mine work by using programing the vcr button as opposed to the tv.
Universal cable company remote control codes
brighthouse remote code for panasonic amolifier to adjust volume
2helpful
3answers
Whats the tv remote code if i have a direct tv + remote.
The Directv remote isn't capable of fully emulating the native remote of the Symphonic Combo. You can get limited functionality though.
1. Move Remote slider to "AV1" position.
2. Hold down mute and select until you get 2 flashes of the green light, then release both keys.
3. Enter 20821 and observe 2 more flashes of the green light.
Next lock the volume controls to this device.
4. If you have moved the remote's slider from the AV1 position, move it back. The slider should remain on AV1.
5. Hold down mute and select until you get 2 flashes then release both keys.
6. Enter 993 and observe 2 flashes.
7. Press and release THE SELECT KEY and observe 2 more flashes.
You can control the TV's power using the big power button under the device selector.
Top Symphonic Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Symphonic Televison and Video Expert? Answer questions, earn points and help others
