Set oven to bake at 350. Oven beeps and shows it is preheated to 350. Baked item taking way too long, and oven doesn't feel hot enough. I reset oven quickly for 375, and the oven shows that it's currently at 295. So it never was at 350. Also notice slight "gas" smell. This happened before, a few days ago, but not the very last time I used the oven. Is there something I can adjust or check?
Thank you!
Kitchenaid superba electric double oven "takes too long to heat up"
Always preheat your oven and let it cycle at least 2 times. Your unit may show 350 but the manufactures know that it is not 350. When it registers preheated, it really means that it is at an acceptable temperature to start cooking. If you think that it may not be calibrated correctly, your owner's manual will have instructions on how to recalibrate your oven. You will be able to raise or lower the temperature by + 25 degrees or - 25 degrees. As far as the gas smell, you will from time to time smell a gas smell with a gas oven especially if you are right at it when it ignites. If you are smelling gas when it is not in use then you should be extremely concerned.
Apparently the computer circuit in front gets fried from all the heat and cooling condensation and then has to be replaced @ $600
