Camera will run for @ 5 seconds then shuts down and message comes up - "reinsert the cassette". This happens on both playback and record. Battery is fully charged. Have tried several different cassettes.
Reel table on the right ( take - up ) if has
low tension ? will slow down or stop , giving
reinsert error : stretching spring ( inside
reel table ) will fix problem , as well as to
order and replace reel table .
Dew has condensed in the camera. Eject the cassette but leave the cassette door open.remove the battery . Borrow a hair drier . set it to optimum temperature(not vey hot but but hot enough to cause discomfort when blown on fingers). direct the hot air through the cassette compartment door for about five minutes. reattach the battery and reinsert the tape.
Good Luck,
Luwangula
Hi, The error C 32:11 denotes for mechanical unsuitability, This problem appears when the improper insertion of the cassette been done, or lose cassette tape stuck, In all these situations mechanical adjustment is required, You are suggested to please contact any expert for the mechanical adjustment. Hope you will understand my sayings. Thanks for using fixya.
The problem is with the S-reel. Take the tape out, remove the battery, and give it a slight bump. This usually fixes the issue for a couple of weeks. I haven't heard of any permenant fixes. I took my cam into circuit city (before they closed) twice for the same issue. Very frustrating when you don't know what the issue is.
I had the same problem and had to leave my camera in for service twice, although I am not using it that much. In the end, they told me they had to change the "head" which cost me about 100euros. If it happens again, I think I will throw the camera in the bin!
Reinsert cassette message comes when mechanism doesnt load cassette properly. If this error message comes again n again, means mechanism has some problem and unable to do task.
Take the battery out and turn selection switch to camera and then turn it off. Put the battery back in and its working again.
if that doesn't work try
Try smacking the side of the camera relatively hard with the palm of your hand. Eject the tape and reinsert. You may need to do this a couple of times.
Hai
Problem in mechanism. If the tape does not loaded completely, the message will show "Reattach the power source" Please check mechanism.
Raghavendra,
M/s.prathiksha Electronics
