Washing Machines Logo
Posted on Mar 14, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Matag top load washer wont spin or empty
When the washer gets to the spin cycle it just stops ...wont spin or empty
Anonymous
Level 3:
  • Maytag Master 3,361 Answers
  • Posted on Mar 14, 2009
Anonymous
Maytag Master
Level 3:
Answers
3361
Questions
Helped
1029932
Points
10654
Set the timer for manually for the spin cycle and trun it on.
If it does not spin replace the lid switch.
I have a Matag Performa washing machine when it gets to the spin cycle it won't spin
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
1helpful
The Matag Neptune Washer unit will not do a spin cycle
If you are having a problem with your top load washer then check out this tip...
Washing Machine2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
My matag atlantis just stopped working. It will
no reset, check the receptical you could have tripped you house circuit or fuse
1helpful
I have a Legacy SAV405DEWW machine wont run
I just had the same problem. The washer would stop about 2/3 through the spin cycle and not start again. Replaced the timer. That did NOT solve the problem.
My washer fills VERY slowly and will not stop filling after cycle
It sounds like the water inlet valve is stuck partially open and needs to be replaced. It's located on the back of the machine where the hoses attach.
2answers
Matag washer Performa shakes badly on spin cycle
Ensure the washer is level by rocking it. If its level should'nt be able to move. You may have a weak floor. to checks this look to see if anything is vibrating around the washer.
3answers
Will not spin Maytag PAV2300AWW top loader
check your door switch. Many times a faulty door switch can prevent the spin cycle. When you locate the door switch, take a jumper wire across the connection and advance the timer to spin. If it spins with the jumper wire, you will need a new door switch.
Zanussi washing machine
Check your filters first, then the pump. Refer to your manual; or click troubleshooting above.............sure would get some tips.
Top Maytag Washing Machines Experts
ZJ Limited
ZJ Limited
john h
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
