When the blower works only on the high setting its usually a bad blower resistor which is right near the blower motor. now you say it would always blow high regardless of the fan speed setting that would indicate probably the climate control unit or a connector problem somewhere. finally it not working at all may be the climate control unit or connection went bad even further. it might have a blown fuse or a bad blower motor in addition to the climate control unit or connector problem .check for power and ground at the blower motor. the power is supplied from fuses and may have a relay also. the ground is supplied from the climate control unit and goes through the resistor to control the fan speed. good luck
I replaced the fan module under the glovebox on my 2005 Town & Country last night. Mine would not shut off at all with key on. It only blew on high no matter where I set the switch. Mine also had the climate control which makes a difference. If it is not the auto climate control it is usually the blower resistor if the other fan speed selections don't blow at all except on high.
Switch the relay with one of the other relays to make sure that this relay is good then go to the HVAC control programer which is behind the floor vent (middle). The Blk/gray wire is the one that supports the relay coming out of the HVAC programmer, but there is a chance that this programmer is bad. If that proves to be the case, I may even have one...let me know.
WELL TURN ON AC MAX COLD HIGH TO SEE IF COOLANT FANS TURN ON.IF NOT YOUR REFRIGERANT SO LOW THAT THE AC REFRIGERANT PRESSURE SENSOR WONT CLOSE CIRCUIT TO TURN ON COOLING FANS.MEANING YOU NEED HAVE AC CHECKED AND CHARGED.ALSO CHECK COMPRESSOR FOR POWER IF NOT YOU HAVE BLOWED FUSE OR BAD RELAY.IF FUSE AND RELAY GOOD YOUR AC COMPRESSOR CLUTCH COIL OPEN OR THE AC CONTROL SWITCH IS BAD.IF COMPRESSOR IS RUNNING WHEN YOU TURN ON AC YOUR AIR TEMPERATURE ACTUATOR NOT WORKING.
the fan relay(resister) that control fan speed is probably burned out.When this occurs it will only blow at high speed because its getting 12volts directly to the fan
fan blower speed switch under hood usually in fire wall or in heater box under dash area if you do not change it you will keep losing all your speeds until nothing left! it is not!!!!the one in your dash that you hand operate! hope this helps.John
your blower control has gone bad it is under the cowl panel on firewall only way to repair is replace this it will be about in the middle of the air box. should be a plastic panel with i think three finger screws you remove it and will see it
all controls work except fan speed
