Need step by step instructions on adjusting the belt on the Weslo Cadence 815 treadmill.
Hi, I don't have a manual on your particular treadmill but most all treadmills use the same type of belt tension and tracking, which is an allen screw adjustment on the rear tension bar. One on either side. You should have been provided an allen wrench with your treadmill, if not then use one of your own the proper size. Make the adjustment with the unit running at its slowest speed. Clockwise tightens the tension and will draw the belt. Good Luck, this should Fixya!
You may need a new running belt if the one you currently have will no longer adjust to be tight enough.
Replacement Parts for Fitness Exercise Equipment at SPORTSMITH
Installing An Icon Fitness Treadmill Belt- No
Exposed Roller Bolts
You can save yourself a
great deal of time by following these instructions as opposed to those of the
manufacturer. Please contact us if you
need any further help. UNPLUG THE TREADMILL
BEFORE DOING ANY REPAIR!
Step #1- Before unfolding
the treadmill, disconnect the lift shock from the ball joint. Most have a small retainer clip that can be
pulled with a small flathead screwdriver and then the shock can be removed from
the ball stud.
Step #2- Unfold the
treadmill and then remove the three wiring connectors for the incline motor and
then one of the incline motor mounting bolts.
Step #3- There are two
shoulder bolts that hold the entire motor tray in place. These are at the back of the motor area and
must be removed to gain access to the front roller bolts. Remove the two shoulder bolts and then you
can pull the motor tray slightly forward or backward to gain access to the
roller bolts.
Step #4- Follow the
replacement instructions included with the walking belt.
Step #5- Reverse the
process of step one, two, and three to reassemble the treadmill.
http://www.treadmilldoctor.com/installation?utm_source=fixya&utm_medium=cpc&utm_campaign=mendi
Need to find a owners manual
I have a Weslo Cadence 200CS and the control speed knob broke off how can I fix it?
When in use it makes a loud roaring sound
brand new treadmill never used but the belt doesnt move on our weslo 5.9
workout select
