Vizio P2 42 in. HD-Ready Plasma Television Logo
Posted on Mar 14, 2009
Vizio remote control not working
I just bought a new VIZIO 47 inch TV from costco.  The remote was working initially, but stopped working except for the volume.  I just got the remote replaced, and now it doesn't work at all.  any suggestions for help?
  • Anonymous May 11, 2010
    It sounds like the IR board problem.
    I know because I just fixed one this week on one of my service calls.
    I am Vizio Service Tech.
Anonymous
Level 1:
  • Contributor 15 Answers
  • Posted on Jun 11, 2009
Anonymous
Contributor
Level 1:
Answers
15
Questions
0
Helped
12317
Points
83
Hi, I had the same problem. My vizio remote for my 42 inch 2 month old vizio also seemed to stop working. Here's what I did: My vizio remote (like most remote's nowadays) was designed for multiple components (tv, dvd, vcr, etc). All you need to do to make the remote work again is set it back to tv. Now, the confusing thing about vizio remotes is that they actually have TWO places where you can switch the remote to the appliance you want to control. One is on top of the remote, the other is on the BOTTOM. Switch it back to TV using the BOTTOM. My remote had stopped working because I had inadvently switched it to another component on the BOTTOM component switch.
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Jan 27, 2013
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
Helped
4286
Points
Visio 32' remote will only turn off & on and volume will not change channels. Have removed batteries and unplugged set but still nothing. Anymore suggestions?
Anonymous
Level 1:
  • Posted on Aug 24, 2012
Anonymous
Contributor
Level 1:
Answers
Questions
Helped
4286
Points
Is it possible you also have another Vizio component such as a DVD player with its own remote? We just discovered while watching a Netflix streaming video that using its volume control buttons adjusts the TV volume - and in the process, its IR signal disables the TV's reception of its own remote signal. We have to unplug and replug the TV to restore its IR connection.
Anonymous
Level 1:
New Friend:
  • Posted on Jan 24, 2013
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
4286
Points
I dont know what to do my power button on my vizio remote doesnt work but everything else does.....
Please help...
Why is menu scrolling uncontrollably when turning on?
Vizio L32 32 in. LCD HDTV Scroll stuck - Questions - Fixya
www.fixya.com > ... > Vizio > Vizio L32 32 in. LCD HDTV
Question about Gateway Flat Panel Televisions. 2 Answers · Menu stuck on andscrolling. menu stuck on and scrolling The TV remote control will not operate the TV, and now the ... Menu Scrolls Uncontrollably ... To turn off the TV, I have to .
Vizio LCD 37 Inch Turns Off Randomly - Fixya
www.fixya.com/support/t354860-vizio_lcd_37_inch_turns_off_randomly
Flat Panel Televisions question. ... I have a 2006 Vizio 37 inch LCD that has started to turn itself off randomly. ..... Why is menu scrolling uncontrollably when turning on? will stop randomly on one input, but will scroll uncontrollably when any ...
Vizio E470VL 47 in. HD-Ready LCD TV Scrolling menu ...
www.fixya.com > ... > Vizio > Vizio E470VL 47 in. HD-Ready LCD TV
Question about Gateway Flat Panel Televisions ... menu stuck on and scrolling TheTV remote control will not operate the TV, and now the menu is stuck ... How to activate the menu choices? try turning tv off and ... Menu Scrolls Uncontrollably.
Need Motorola cable box DCT2224 code
If you wish to get more; check the site linked here. It has set-up code list & set-up procedure to many popular brand remote controls. See it in "Mosaic" view. It will make surf easier.
http://electrohelponline.blogspot.com/
Try this link too
http://remotesearch.blogspot.com/
1helpful
I have had my Visio 47" for 3 years. One night the screen just went blank. I could not turn it off with the remote. I manually tuned it off. then used the remote to turn it on. The Visio light and...
it sounds like you need to purchase a new video board from vizio which is expensive. upwards of 600 dollars. walmart has vizio 42 in and 47 in 1080p models around 500 dollars on sale this weekend. hope this helps let me know!
I have just bought the 42 Inch Vizio from costco and it worked fine for two weeks and then the remote stopped working. Also the DishNetwork remote which I used to control the TV and the DN 622 can not...
We're sorry to hear about Vizio TV remote, but we would be happy to help you with getting your DISH Networkremote to control your TV. We're going to start by pressing and holding the TVbutton located on the top of your remote until all mode button back lights comeon, and then release. Use the number buttons to enter the codes for your Vizio TV; here some of the codes we currently have: 505, 598, 627, 520, and 766. Press the pound (#) button. To check that the code works try severaldifferent functions on the remote to make sure it will properly operate the TV.Remember that some codes may not be compatible with your equipment. If this isthe case, try the other codes listed for that device until you find one that iscompatible with your equipment.
We hope this helps and thank you for being a valued DISH Network customer!
Phillip Chang
DISH Network Customer Service Representative
3helpful
I have a moxi box and i just bought a vizio tv and i cant find the code so i can use the volume control on the moxi remote or to turn off the tv either
The Code for the Moxi Cable box remote control for VIZIO TV's is "1178". I just programed my 47" VIZIO TV with this same code
Vizio 47" Costco hdtv has red floating areas!
After posting this problem we did call Vizio. They sent out a repairman (had to wait over a week) who fixed it by: Replacing the LVDS cable and the main board. (Just like somebody on this blog wrote somewhere!) We also had just previously called our cable company who came out (also free) and checked our system only to find the cable running around the house to the tv needed replacing as it was sending zillions of errors. The red flowing problem (called "red pixilation") was due to the Vizio LVDS cable and main board being faulty from the factory.
Just want you out there in web land to know how to get your similar problem fixed!
2helpful
2answers
Programing Dish Network Remote to control a Vizio Tv.
Try 627 for Vizio TVs - that should work on the Dish remote.
3answers
Pop of Death
Having the same problem except on a 32 inch LCD
153helpful
14answers
Television will not turn on
My 47" Vizio wouldnt turn on this morning.....had a similair problem 3 yrs ago.....this is what i did and fixed the problem myself.....apparently you have to reset TV. Here is what has worked for me. So unplug tv power cord from the tv. Hold the power button and imput button together ( located on side panel ) for approx 45 sec......plug cord back into tv. Press power button on tv and voila !!!!! Tv came back on!!! I have had my Vizio almost 5 yrs. But have to call the unhelpful customer service atleast once a year.... I hope this works for you :)
Top Vizio Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
