I bought my oven in June 2012 and it was OK for 6 months and then it started tripping the main RCD (to begin with intermittently) I contacted SMEG engineer and he replaced fan unit and elements. It was OK for three weeks and it has now started again, tripping every 2 - 10 minutes when cooker is on (top or bottom oven). Can anyone help with this or should I call SMEG engineer again
SOURCE: cooker not heating up
removed broken element and replaced it. You have to access the fixing screws from the back of the cooker to remove it
SOURCE: suk92mfx5 main oven problem?
the fan element would have blown. it is not uncommon for an element to trip an rcd when it blows. you are on the right track, if you replace the element all your problems should go away
SOURCE: Smeg SUK91MFX5 oven overheating
REMOVE BACK PANEL TURN OFF POWER CHECK WIRING TO & FROM CORD BLOCK
