Question about NorStar M7208 Corded Phone
Doesnt ring My phone Norstar M7208 doesnt ring
  • Vitaly Kagan
    Vitaly Kagan May 11, 2010
    If someone called you within office does it ring?
My BT Meridian compact does not ring after it powered down in a thunder storm. The lines flash and can be answered as normal just no ringing sound
Posted on Jun 16, 2009
SOURCE:
NorStar M7208 - How to remove global ringing?
This is tech side of programming and not Admin, if you don't know config password or how to program then call a tech.
If you do know then:
First find out what line #, do F*0 then press the button and note the full number on the display.
i.e. Line 5 in programming is Line 005, 025 or 031 depending on software version.
Sets/LineAccess/LineAssignment/Show line ***/Change to Appear Only or Not Assigned.
Jul 25, 2012 | NorStar M7208 Corded Phone
Norstar meridian 7208 won't ring.
Does it ring when you move it to a known ringing port? Is it programmed to ring (Terminals & Sets) Appear and Ring? Do you have Automatic Set Relocation turned on so the extension number stays with the phone?
There are a lot of features to check for ringing, including the volume of the set.
Carl
Sep 10, 2011 | NorStar M7208 Corded Phone
Our office has a combination of Norstar M7310 and Norstar M7208 phones. One of our M7310 phones died today and I wanted to trade it out with a M7310 that was in my office. I followed how to turn off the...
Dial "F * 0" (Feature, star, zero), which is Button Inquiry, and press an intercom button to see the extension number of the telephone. If Set Relocation is set to "Yes", then the extension number & mailbox will follow the phone when it is moved. Move only two phones at a time, and wait until they completely "boot-up" before moving additional phones.
Hope this helps.
Aug 04, 2010 | NorStar M7208 Corded Phone
Norstar M7208, it's direct line number is diverting to another ph
It could be a simple as the phone has call forwarding to another extension set up on it or the direct line could also be programmed on the other set. Does the screen on the non- ringing m7208 display "forward to:xxx" or does it display the current day and time?
Jul 01, 2010 | NorStar M7310 Corded Phone
Norstar M7208 - Only 1 of 3 phones will ring
Programming is done on M7310, M7324 and T7316 sets.
To set up ringing you need to enter programming by pressing the feature key followed by **266344.When prompted to enter the password enter 266344.
The screen should say TERMINALS&SETS. The 4 top line/feature keys are now used for programming.
At the terminals&sets prompt, press the show key (top right arrow). The display should now ask for an extension number. Enter extension number you wish to program ringing on. Press the show key (top right arrow)
The display should sat LINE ACCESS
Press the show key (top right arrow) .
The display should say LINE ASSIGNMENT.
The display ask for a line number. press list
The display should sat line 001: appear only press CHNG til it says appear &ring.
press next key (lower right arrow)
The display should say line 002: appear only
Repeat same procedure as line 001 til all available lines are done
press the release key when finished
Sep 21, 2009 | NorStar M7208 Corded Phone
My Norstar M7208 phone wont ring. We've moved into a new facility and the ringer does not work now.
Is set relocation on?
If not then probably what has happened is that the new station port does not have ringing programming of the old port.
if you know how to do this go into riging programming of the set and activate it
Aug 03, 2009 | NorStar M7208 Corded Phone
Incoming calls briefly ring once then automatically kick over to answering machine. I cannot get any incoming calls
Are you using norstar voicemail system?
If you are and know how to get into the admin programming of it, then you go to the line programming and select the number of rings before the vmail system answers.
set the rings to "3", then the lines should ring 3 times on your phone, then on the 4th ring the vmail system will answer
Jun 26, 2009 | NorStar M7208 Corded Phone
Phone will not ring
It's RINGING now! I followed the Set Programming instruction in our manual. It's in Configuration 3-21. It's a very old old Operator guide.
I am trying to find it online. In the mean time you can use the M7208 Phone Adminitration Overlay over the keys and program your phone by pressing Feature **266344
Here is a link to the overlay
Good Luck.
Nov 19, 2008 | NorStar M7208 Corded Phone
NorStar M7208 Corded Phone Logo
862 people viewed this question
Top NorStar Lands Phones Experts
Marvin
Marvin
Thomas F. Schneider
Are you a NorStar Lands Phone Expert? Answer questions, earn points and help others
