Coolant problem
Sounds like you might have an air pocket in the cooling system. This can develop, usually after a service, where the cooling system has to be opened to replace a water pump, thermostat, or other reason. When refilled, the air displaced by coolant has to go somewhere. In many cases, youll find that air is trapped in the highest place it can go...above the level of the radiator cap or overflow bottle. This can be a portion of the upper rad. hose, a heater hose, or a coolant line running thru various parts of the intake/throttle body area. What I do after topping up the system, is let the engine warm to normal op. temp./ W radiator cap still off. When upper hose becomes hot, you know thermostat is open. Now, if a bleeding device is not present, back off a hose clamp at the highest point in the system. Take a pair of pliers and twist the hose just enough to break the seal. You should see steam or drops escaping from your "breach". Once the steam stops and becomes all coolant, you have likely bled all air from the system. Top up radiator and coolant bottle to proper mark and close the system. (tighten your hose clamp) Check for leaks. Keep an eye on your system for a day or two, to insure no leaks are present.
Road
Caution! As with any task that involves opening the cooling system...Coolant and water can become very hot. Hot water and steam can be very dangerous. If you dont feel qualified to perform this task, let a mechanic do it!
Please Rate me by scrolling down to the colored flags and choose which catagory best fits my response.
Thanks.....
