Whirlpool Duet GHW9150P Front Load Washer Logo
Posted on Mar 14, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Error code f22 whirlpool duet wash cycle
Error code f22 appeared about 30 seconds into whirlpool duet wash cycle-
door is looked, nothing happening
  • sujo187 Mar 14, 2009
    Thanks- tried it twice, it is still not cooperating.
Starnley Johnwells
Level 3:
  • Master 1,031 Answers
  • Posted on Mar 14, 2009
Starnley Johnwells
Master
Level 3:
Answers
1031
Questions
Helped
607671
Points
3590
F22 is a door lock error try this hit cancel turn your dial to another setting, hit start and once it starts hit cancel again and it should unlock. thats what i did anyway.
If you're getting an F22 error, you will want to check anything to do with the door latch switch.
  • 1 more comment
  • Starnley Johnwells
    Starnley Johnwells Mar 14, 2009
    hope this helps pls do let me know if you need further help
    tunplug it from all source of power supply then back after like 1hr if it still continues then you can replace the door latch switch
  • Anonymous Oct 02, 2012
    I am having same problem replaced door latch and still diagnostic test saif F22
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on May 31, 2013
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
9776
Points
IT DOES NOT SHOW ERROR CODE F22, THE WASHER MADE LOUD NOISE WENT DOWNSTAIRS AND THE DOOR WAS OPEN AND THE CYCLE HAD STOPPED, I TRY TO SHUT DOOR TO FINISH THE CYCLE , THE DOOR WILL NOT SHUT OR LOCK
1helpful
Whirlpool Duet Washer F22 Error Code Follow-up
1) F22 mean DOOR LOCK ERROR , this problem can be a) switch for open or defective b) loose wires or broken wires, test by continuity VOM .
2) adjust the Door vs switch very well for propely closed, and test the closed switch.
3) see if the color are missing and put in the WRON terminal.
God bless you
I am getting an F22 error code on my washer. Can anyone tell me what this code means.
Look at the information below and it should clear up your mystery.
F22
DOOR LOCK ERROR
A Door Lock Error occurs if the door cannot be locked. It will try to lock it six times before displaying the error code.
Possible Causes/Procedure ??  Door lock mechanism is broken or removed from door.
??  Door switch/lock unit failure.
1. Unplug washer or disconnect power.
2. Check door switch/lock unit.
3. Check the wire harness connections to the door switch/lock unit and Central Control Unit (CCU)
F22 code ?? duet locks but will not run
"F22" is a door latch failure error code. At the beginning of the wash cycle the door will attempt to lock several times. If the latch fails to lock, the washer shuts down and the error code is displayed.
In some cases, the error code can also be displayed if the CCU goes bad. There is a door latch relay on the board that controls the door locking mechanism. The CCU is not serviceable and must be replaced if defective. In addition, make sure all the connector plugs between the CCU and door latch are connected and snug.
Thank you !!
What does F22 error mean?
This fault code denotes 6 failed attempts at locking the door. I have found that this code is typically indicitave of a failed lock. Check the strike on the door to be sure nothing boke on it, and if not get a replacement door lock assy for your machine. You will see the three screws that hold it in and can remove the front spring clamp from your door boot to give yourself access to the door lock.
Good luck to you on this!!
1helpful
What is code F22 on sport duet washer? The locking mechanizm buzzes a little, and when you push start it's locked and stays locked, and you have to stick your hand up in it to unlock it.Thanks.
Thank you !!
Whirlpool duet had code of f22. door was locked, i manually got it open but now the controls still do nothing. i tried resesting..
Switch on the machine. Press and hold "end of cycle" button for 3 seconds, on the right side of panel. This is the child lock feature, do it again & it locks.
If helped, pl rate me good!!
F22
I have search for this and found:
This error code indicates that the door is not locking.
Is the washer door firmly shut?
The door must be completely closed for the washer to operate. The door may look as if it's closed, but it may not be latched. Open the door and firmly close it.
Were you washing a large load?
Before you close the washer door, check for laundry items sticking out beyond the door opening. Leave enough space in the washer to allow the clothes to freely tumble. Reduce your load size if needed.
More info can be found on The Whirlpool website:
Whirlpool Front-Loading Washer
3helpful
Whirlpoo; wfw9200 F22, F28, A17 A27 error codes
f22 is a door lock error and f28 is a commication error you still have warranty thorugh whirpool. you're going to need pro. help
F 22 front door locked and door won't open.
hi there,
the F22 stands for the CCU/Touchpad error. in other words, the keypad has lost connection with the control board behind it.
this is what you do:
unplug the washer
take off the console
check the connection between the touch pad and the CCU boad
make sure that nothing looks corroded or burnt
make sure that nothing is pinched or bent
unplug and replug wiring harness and connections form keypad to the CCU board
let me know if it this works.
2answers
F22 Error Code
TAKE 3 SCREWS OUT THAT HOLD THE BOTTOM FRONT PIECE REACH UP BEHIND AND ON THE DOOR LOCK MECHANISM THERE IS A ROUND PLASTIC DOOHICKEY PULL IT DOWN ABOUT 1/2 AN INCH OR AS FAR AS YOU CAN AND IT WILL UNLOCK THE DOOR. I WOULD UNPLUG UNIT FIRST. I DON'T KNOW ABOUT THE F22 THING. MY JUNKER DOES THE SAME THING PERIODICALLY, I UNPLUG AND REPLUG IT TO CORRECT
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
