Hi there
I've had this SL Turntable system for some time now, and it's been starting to stop at every scratch on the vinyl there is, even when i play the ones that are in mint condition.
What's there to do?
SOURCE: SL-1200MK2 SOUND ON ONLY ONE SIDE..
More than likely this metal ball is the one that is used with the on/off switch.
SOURCE: I have a tecnics turntable and need to know how to
Lift off the rubber platter cover (the disk that records set on while playing) there should be 2 openings in the aluminum plate. Slowly rotate platter until you can see the pulley of motor. Lift aluminum platter straight up and off. Place belt around underneath pulley on platter. Reinstall platter to turntable. Reach through one of slots in plater and grasp the belt gently, line up slot with motor pulley and place belt over pulley (ensuring not to twist belt) rotate platter to observe belt, confirming correct installation. Reinstall rubber platter cover. VOLA!
SOURCE: how do i change my nite lite on t1200
I have a guide on my website :-
http://www.technicsdjuk.com/repair
does the motor itself shut off or does the sound cut out?
