Hi Kaitlyn.
see if this link helps you to find out why.
A100 won even turn on
or this one.
https://community.acer.com/en/discussion/41413/acer-iconia-tab-a100-wont-boot-anymore/p2
or this.
Help my Acer a100 won power up
SOURCE: acer 9300 overheating problem
it doesn't sound like you are too computer savy...so I suggest you find another computer shop to fix both problems for you
SOURCE: when i press the power button my acer aspire one.it wont boot
I recommend you try the steps in the below link:
http://notebook-solutions.blogspot.com/2009/05/notebook-solutions-notebook-solutions.html
Follow the steps from No Boot or no Power in laptops.
Also check if there is a known issue with your laptop model since even others are experiencing similar issue.
SOURCE: the power button doesnt seem to be working
It sounds like a short in the button itself. If you have a soldering gun, take it apart and resolder the connection. This is typical for Acer laptops.
It's either the button itself or the jack where the power supply plugs in. It's not real difficult.
SOURCE: My acer d250 laptop wont turn on unless it is plugged in
Clean the baterry connector port with an alcohol solution or Spirit solution.and try.
If you can get hand to another battery,check out if everything is fine.Otherwise replace the battery.
Check if you have warranty of the battery.
SOURCE: Ive had my acer aspire 6930 for about a year now
sorry - i have the same sound problem and found the same temporary fix - have you had anyone solve this for you? I actually have two recently purchased acer laptops - both have same problem
