Question about Electronics - Others
Can't use menu function on remote control for pioneer krl-32v TV
I bought a new Pioneer 32'' TV last weekend but after a few days of everything being ok was finding that whilst many buttons on the remote worked fine (eg choosing input line & volume controls) I didn’t get any response when I pressed the TV/DTV/radio/EPG buttons and most importantly from the menu button. I was able to get into the menu via the buttons on top of the TV but in trying to sort the remote problem I inadvertently locked them by switching the ''button control lock'' on. So now I can't get into the menu at all to set my system up for my home cinema. Can anyone suggest a solution? (I should mention that for the first few days at least all the buttons seemed to work on the remote).
  • 161 Answers
Ok try this first, remove the batteries from the remote and yes make sure you replace them with brand new ones, but before you do that unplug the tv from it's power source and let it sit for a couple minutes at least 3, then plug it back in , put the batteries back in the remote and see if you have everything back, if not I would return everything since you said you had just purchased this set, or contact the makers web site and see if they will provide a new remote since taking the tv back is a real pain.
Posted on Mar 19, 2009
6ya staff
SOURCE:
How can i adjust the color/contrast on my Pioneer Elite Pro-510 Hd without a remote?
Not all universal remotes control all functions of a particular device. A different universal remote might work as the code libraries differ from one to another.
Sep 10, 2014 | PIONEERPOS 15 Inch M5 PNT-M/2G 512MB 80GB...
Pioneer KRL-37V manual
Hi my HDMI is not connecting to my tv any more it says there is an incompatible video signal being received, something along those lines. please help!!
Oct 20, 2011 | Pioneer Kuro KRL-32V 32 in. LCD TV
No original remote for the following TV pioneer model pdp-506pg need to get into the main menu and set up my dish and program the new remote so need the code for the tv.
Everything you need to assist you in your task can be found at www.Dishnetwork.com . Go to programming features. You should see an option for satilite(dish). You also will need to go to "programmable codes". Jot down these codes. There will be at the least several. Next go to programming instructions. Follow these easy instructions and suffice to say...you'll be watching DISH NETWORK within minutes! Have a GREAT day!
Jan 28, 2011 | Pioneer Televison & Video
Pioneer 428xd tv remote control code wanted
if you have gone through all of the codes in the manual for pioneer, and they dont work, then your last option with that remote is to use the "code search" feature.
otherwise you're going to have to find a remote that will work for that unit, because its not exactly new :(
Sep 24, 2009 | Televison & Video
Remote control dosnt work on this tv
I have the same plasma Pioneer tv. I also tried a replacement remote and no fix. I replaced the infrared receiver module (~$4 from Radio Shack) on the TV, yes it involved taking the tv apart. Voila, now I have two working remotes.
May 12, 2009 | Pioneer Televison & Video
Pioneer SD-582HD5 - screen went black, no sound, Poor remote feed
The blue tube might be leaking coolant in the high voltage area, that is the cause of the POP. This repair might not be a DIY because of the lethal high voltage surrounding the CRTs tubes.
The slow response from the remote could be because the coolant has affected the main board where the IR signal are going to the remote sensor.
Let me know if you require further assistance.
Dec 20, 2008 | Pioneer SD-582HD5 58" Rear Projection...
No sound at all
Sometimes you need to make sure the REMOTE line is hooked up, which is the blue-wire with the white stripe.  If it isn't hooked up, this can cause the unit to function, but you won't get any sound.
Jan 06, 2007 | Pioneer AVIC-D1 Car Video Player
Electronics - Others Logo
129 people viewed this question
Top Electronics - Others Experts
Marvin
Marvin
Tom Chichester
Are you an Electronics - Other Expert? Answer questions, earn points and help others
