When trying to connect asus M51V notebook to panasonic TH-42PX8A plasma TV via HDMI connection the notebook seems to detect the TV but no amount of adjusting the input resolution parameters will enable the TV to show the display. Similarly, when trying to connect to the same TV via RGB input, the display will only 'extend' but not show the full display. ?what to do.
Hi
Make sure your TV does indeed support the resolutions you are trying to use. Some low quality HDMI cables can also be troublesome in higher resolution so try one you are sure to work.
Regarding to the desktop only being extended when using the RGB cables, try bringing up the desktop properties window, select the TV as the primary monitor and select "Use this monitor as Primary monitor". You might have to drag the windows Taskbar over to the other monitor, just rightclick the taskbar, uncheck "Lock the Taskbar" and drag it over to the other monitor.
Hope you find this solution helpful, and please rate it if you do so..
best regards,
Karl
