Just had the exact same issue with my F&P it would stay in the drain cycle(without draining). It would show 2 minutes left in the cycle, dropping to 1 minute, but would never complete the cycle.
For some reason the machine would not drain the water from the drum and would continually remain in the drain cycle, spinning the load(back & forth), but not draining the water.
This is how I sorted the machine: -
1. I turned off & unplugged the machine.
2. I drained the machine manually. Opening the manual drain compartment located at the bottom right of the machine.
a). Firstly drained the majority of the water using the small black hose into a plastic container(ice cream container will be fine). Took a little while as the machine was quite full and I also didn't want to flood the laundry.
b). Once I had drained most of the water I undid the filter plug to drain the remainder of the water, which wasn't too much & was able to mop up with a towel. I gave the filter a good clean, removing as much build up in there(which in actuality was very little lint, gunk, etc. Though I did find a small button & a collar stay wedged in there).
3). I blew very hard into the washing machine drain hose a few times(read this on another forum so thought I'd give it a try!). Use a plastic bag, etc. to cover the hose etc. for hygiene purposes :)
4). I then plugged & turned on the machine. The machine went straight back into the 2 minute drain cycle. It attempted to drain/pump remaining water, however this time machine successfully went through the 2 minute drain cycle. Machine stopped, counted down, click and I was able to open the door.
I put the washing through a rinse setting to see whether the machine would complete cycle. I can happily report that the machine completed the rinse cycle on the washing with no issues. I also put through another load to see if it would complete a full wash cycle, which I can report it happily did so.
This may have just saved me a grand$ :)
Good luck.
cheers
Monkeyboy :^)
