Dell Inkjet 720 Printer Logo
Posted on Mar 14, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Dell Color Printer 725 - Communication Not Available
The following window pops up when I try to print something through my dell 725 printer:
___________________________________
The printer cannot communicate with the computer.
Try these solutions:
-ensure the printer is powered on
-disconnect and reconnect the printer's power cable
-disconnect and reconnect the USB cable
-Check your firewall settings to ensure printer communication is not blocked
-restart your computer
I tried all of that. I recently installed a wireless network in my home and did a bit of shuffling with USB ports recently, but I put things back in the ports where they should work. Does that affect anything?
Please help! :(
Himko Dondy
Level 1:
Welcome Back:
Visited the website for 2 consecutive days.
Problem Solver:
  • Contributor 10 Answers
  • Posted on Nov 06, 2019
Himko Dondy
Contributor
Level 1:
Welcome Back:
Problem Solver:
Answers
10
Questions
0
Helped
12554
Points
26
If something turns out seriously with your Dell printer, you endeavor to fix it isolated or you take neighborhood course of action which you consistently find costly and not 100%. Thusly, we brief that you can get called "One Search Point" gave by us. We offer a quick number that you can call and banter with the Dell specialist on the phone and discussion about the issue with your Dell printer. Inside a minute, your worry will be understood and in case it requires further support, by then you are given that moreover
Dell Printer Support Phone Number.
https://www.onesearchpoint.com/dell-printer-support-phone-number/
Anonymous
Level 2:
Scholar:
  • Expert 85 Answers
  • Posted on Jul 29, 2009
Anonymous
Expert
Level 2:
Scholar:
Answers
85
Questions
0
Helped
48448
Points
215
I have seen that in most of the cases (with lexmark and dell printers) it is fixed by reinstalling the printer software. Be sure that you completely remove the older drivers using the cd or using add/remove programs.
Dell 725 won't print saying unsupported cartridge
Had the same issue, bought some cheap inks off the internet and the printer wouldn't accept them, bought the proper dell cartridge did a head clean and it worked ok.
1helpful
I change the ink jet on my dell 725 printer, and the printing is so faint.
Are you using Dell Series 6 ink cartridges?
Unplug the printer from the wall. Now remove the power brick from the back of the printer for 60 seconds. This will reset any error messages the printer has.
Plug everything back in and power on the printer. Now remove the Dell Series 6 Color cartridge. Make sure the tape is off the cartridge and reseat the cartridge. Then close the printer and it will print an alignment page. Any error messages?
Dell Series 6 ink cartridges have a sensor in them that cannot be reset. Article on refilling Dell ink cartridges
Dell Series 6 ink cartridges can be purchased at Staples, Walmart or Dell's Website.
It is possible the cartridge has a bad sensor. Try taking it back to the place of purchase for a replacement.
Rick
2helpful
Dell 725 printer wont print after windows 7 install
You need the correct drivers for the printer. Go to Dell's support page and download and install the Windows 7 driver.
I have had this printer for about 2 years or so. It used to work. Now it gets frozen on the USB printer port page when I try to print. So I went to the dell printer driver page and downloaded the printer...
no need new printer first uninstall old printer drivers from computer then check your printer model number and download exact driver again then install.
4answers
Dell 725 USB printer says catridge not present when it is
i think you will have to take the printer to the service center as it needs servicing, there might be a problem with the cartridge holder
Color printing
When you print something and the window pops up, go to preferences and youll be able to specify "black" as the output color.
6helpful
Communication Error DELL 926 AIO Printer
Found on another forum. For 926 this worked great.
1. Go to Control Panel - Printers : Delete 926 printer
2. Go to Control Panel - Programs and Features : Uninstall All Dell 926 related software. There should be 3 programs. (When prompted to restart, respond to wait.
3. Rename Folder C:\WINDOWS\SYSTEM32\SPOOL\DRIVERS\W32x86 to W32X86OLD
4. Now restart your computer
5. Reinstall 926 Software.
This worked terrific for me.
2helpful
Follow these steps in order to resolve the issue:
Stop the Print Spooler Service: 1) Click Start. 2) Type ‘cmd’ in the Start Search box.Search results should appear. 3) Right-click on ‘cmd’ in the search results, and select Run as Administrator.The command window will appear.4) Type ‘net stop spooler’ into the command window and press <ENTER>.The Print Spooler service should now be stopped.
Delete the Printer Drivers: .
1) Click Start.
2) In the Start Search box, type ‘C:WindowsSystem32SpoolDriversw32x86’ and press <ENTER>.
3) Delete all the files and folders in this directory.
NOTE: If the folder will not delete, rename folder to w32x86.old.
Remove the Dell printer software:
1) Click Start.
2) Click Control Panel.
3) Click Programs.
4) Click Programs and Features.
5) Click the software related to the attached Dell printer to highlight it.
6) Click Uninstall/Change.
7) Follow through the prompts in order to remove the software.
8) Restart the computer.
At this point, the user should install the latest printer software from http://support.dell.com and be able to print successfully.
3answers
Error Message "Communication Not Available
Please open the link and follow the instructions this will definately resolve the issue, and please respond with comments to impove better service and resolution
Communication Not Available" Error When Sending a Print Job
http://support.dell.com/support/topics/global.aspx/support/dsn/en/document?c=us&dl=true&docid=2AA10ED87ADC4C0EE040A68F5B285B98&journalid=45AF3C8CB5A7BDF9E040A68F272874F0&l=en&s=gen
Regards
Won't print black
MY DELL 725 PRINT WILL NOT PRINT IN BLACK INK. I HAVE A NEW PRINTER. I EVEN BOUGHT A NEW INK CARTRIDGE AND IT STILL PRINTS IN GREEN ONLY. WHAT CAN I DO TO HAVE MY DOCUMENT PRINT IN BLACK?
Top Dell Office Equipment & Supplies Experts
Grand Canyon Tech
Grand Canyon Tech
Norman Weimar
Norman Weimar
Ngoro
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
