Can't detect outside temperature sensor
SOURCE: NEED Manual
Here's a link to all the manuals:
http://www2.oregonscientific.com/service/manualmodelSearch.asp
SOURCE: Wireless thermo clock not reading outside temp
I've had a similar problem with another model, an Oregon Scientific Model IWA-80055 Wireless Thermo Clock, in which when I replaced the batteries in the remote sensor, the clock would not read the temperature from the remote sensor.
I found it fairly consistent to solve this by taking a battery out of place in the clock and putting it back in. Unfortunately this also messed up the clock's time and date. This is also in the instructions catalogue for the device, check and see if yours gives a similar solution.
SOURCE: I cannot open the remote sensor for my Oregon Scientific PSM06AR.
I believe the back of the sensor slides open. There may be a faint arrow on the back that indicates the direction in which you push.
My unit took well over 24 hrs to reset. I think it has to do with the position of the satellite in relation to where you live.
SOURCE: Oregon Scientific Model 323a--Atomic clock...the
Make sure that the clock is set for the correct time zone and that the DST (Daylight Saving Time) function is ON. Also, although not mentioned in the manuals, these clocks will typically jump and hour ahead or behind when the batteries get weak. Replace your batteries if they are more than a year old.
Bill B
