When I use my mixer the paddle, of late, is rubbing the bottom of the bowl, which is causing the white enamel on the paddle to wear off. This enamel apparently is going into what I am mixing. Isn't there an adjustment that can be made to prevent this?
You did not do anything wrong in fact it is the correct procedure to stop the scraping. Later if the beater starts to scrape again you may need to replace the screw because it is a nylon screw and if it keeps coming out it is worn. You can get the new screw off the internet and it will cost about 6 bucks.
It is going to low down. the adjustment should at the back of the unit.
I adjusted the screw under the motor head and it seemed to take care of it. Please let me know if I did the wrong thing.
ijwilson
