When I press the start button the Windows screen comes up like it is going to open up but instead it goes to Startup Repair. After the computer does the Repair search, I reboot and the Windows Starting screen comes up but then it goes to a screen with only the arrow curser. Nothing else happens.
SOURCE: After using recovery disc and
This is caused by the resoultion of the graphics card not being set to suit your monitor.
Right click on the desktop, and choose 'properties' from the list
a new dialog box will appear called 'display properties'
along the top is a series of tabs, the last one is called 'settings'
click on this and you will then see details of your screen resoulution.
Halfway is a slide bar called screen resoultion
for example..
less -------|------- more
move the slider untill the numbers change to 1024 by 768 pixels
to the right is another box called colour quality - change this to 'highest (32bit)
click apply
click ok
the screen will briefly go black then you will see the desktop, you will get a confirmation box asking along the lines of 'do you wish to keep these settings' click yes to this
have a play with the desktop, open some windows and see if they are now fully visable to you without having to scroll.
You can go back and change your resoultion anytime you want, by following the above. But take note, some monitors will not display all the resoultions in the list, you will get a message to say if it is or not. Just play with the settings untill your happy.
Hope this helps
Regards
SOURCE: Sony Vaio PCV-RS710G wont start up
one of the files in the system32 directory in the windows folder is corrupt, the files in the system32 folder contains vital files for the boot procedure, try to start the machine in "safe mode" by pressing F8 after the sony boot screen, if it allows you into the operating system you will need to choose "system Restore" take the time back to at least a week before your problems started DO NOT CREATE A RESTORE POINT
SOURCE: Cannot start Sony VAIO PCG-5J2L /Goes to black screen only
During start-up the computer will go to a black screen for awhile and then the pointer arrow will show alone, and then the system will come up.
If you think it's a hibernation problem, pull the ac plug and battery out for about 1 hour and then plug back in.
If this didn't work, then try the F8 Key and choose "Last Know Good Configuration".
SOURCE: PCG-8P3M starting problem
Hi there
plug an external monitor to the laptop to rule out the inverter
post back
SOURCE: when i press the x button to start the blue ray
What happens when you try to play PS3 games?
