The past two weeks I've had problems w/the foot pedal either FF or rewinding while pressing play & nowhere that I touch on the play part will it play. . . sometimes the FF part of the pedal won't work either. Yesterday while using it, when I pressed on rewind, it played instead. It seems to be totally out of whack. My husband fiddled with it a little bit & it started working, but then quit after testing it a few times & is back to FF or rewind while pressing play.
It's possible that there's a broken wire in the cable that connects the foot control to the machine. This usually happens near the plug that plugs into the machine, or by the end that goes into the foot control.
You can usually duplicate it if you put the auto-backspace up a bit and then hold down the play pedal on the foot control. While holding down the play pedal, try moving the cable near the machine or near the foot control in a circular motion. If the machine stops, rewinds or fast forwards, then odds are that the problem is with the cable.
Hello sounds like a fott pedal problem when you have the problem unplug the pedal and try your unit using the front butons if your unit works normal you can buy a foot pedal replacemet at
http://www.tvps.com/Products/ECS-IN-585-Heavy-Duty-Foot-Pedal---Pre-Owned-IN585__ECS-P-IN-585.aspx or
http://www.tvps.com/Products/Dictaphone-177585-****-Shell-Foot-Pedal---Pre-Owned__DI-P177585C.aspx if you want a new one http://www.tvps.com/Products/Dictaphone-177601-Heavy-Duty-Foot-Pedal---New__DI-177601.aspx
Hello on a BM-147 there is only one adjustment responsible
for auto back space when you used foot pedal and that adjustment is next to the Display is
call Reverse Time that controls the reverse function when you take foot control
off from play but if the problem is when you take the foot off on REW and unit
keeps going you have a bad foot pedal you can get a replacement at http://www.tvps.com/Products/ECS-Sony-IN-75-Heavy-Duty-Foot-Pedal---Pre-Owned__ECS-PIN-75.aspx
