You will hear a beep, then the words Sirius Seek List appears on the screen and starts listing songs randomly for usually less than a minute. It stops on its own, and within 2-3 minutes, does it all over again. It cannot be turned off from the menu. The only way to turn it off is to clear memory. However, when you do that, you disengage your ability to listen to your 30 preset songs it took months to finally load.
Called Sirius today, said a software problem, they can't fix. Said only way to solve problem is clear memory. Wow!, here I go again. Amazing how that feature is on the Starmate, yet they say it's a software glitch. How's that? That feature cannot exist on the radio unless it was written into the program. So how can it be a glitch? They don't even know how to turn it off. DOES ANYONE KNOW HOW TO DISABLE SIRIUS SEEK LIST?
Http://www.sirius.com/pdf/manuals/ST2-User-Guide.pdf
See page 24 on [or search for alert]. It's taken me a while to find this as I HAD the same problem
Unintended reverberation, or "echoing," from your computer speakers is a common problem that can arise from improper setup of your audio properties.
Resetting all of your audio information to default will correct this problem, allowing you another chance to strike a good balance to satisfy your audio tastes.
This can be accomplished by accessing the Sounds menu in your operating system.
Select the "Start" menu from the bottom-left corner of your screen, and click on "Control Panel." Find the "hardware and Sound" button and click to select.
Click on the sound icon and select the third tab labeled "Sounds" in the window that appears. A list of sounds will appear, beginning with "Asterisk." Click on a sound to highlight and select test.
Listen to hear if the echoing problem occurs.
If it does, you need to configure your speakers or check to see if it is a third-party issue.
Select the first tab labeled "Playback" from the same window. Right-click on the "Speakers" icon. Click on "Configure Speakers" from the top of the list.
Choose a setup from the list that appears and select test to test different sound configurations for the speakers.
Listen to decipher if one configuration has less echo than another. If so, choose the speaker configuration without the echo to fix the problem.
However, if none of the configurations remove the echo, you need to attempt to troubleshoot the issue from "Safe Mode."
Turn on your computer if it is off or restart your computer. Continuously press the "F8" key until the "Advance Boot Options" screen appears.
Use your arrow keys to navigate the screen, pressing down until you have highlighted the "Safe Mode" option. Hit "Enter" to select. Wait for the drivers to load.
Log on from the "Administrator" account. Test the sounds again, and if the echo does not occur, the cause is a third-party driver or service.
hope this helps
