Uninstall the keyboard driver and let windows driver manage it,Should work fine.
I'm assuming the external keyboard is unplugged when you do this? If so the kb buffer is bad or the BIOS has been set to an external kb only. To check the BIOS press F2 when the machine boots. Go into BIOS and look for an external keyboard setting.
WHEN YOU TURN THE MACHINE ON PUSH F6
AS THE SYSTEM BOOTS
AND SELECT SAFE MODE
ROD
You need to try booting in Safe Mode with Networking and if that fails then Last known good configuration should work. Below are the steps to perform Last known good configuration howver Safe mode with networking is also an option under "windows Advanced option". Now if you succeed logging in to Safe mode with networking then try performing system restore by going to Start....All Programs....System Tools and System restore.
Follow the steps below,
Step 1: Shut down your PC completely.
Step 2: Turn on the Power button.
Step 3: As soon as you turn it on start hitting the F8 key on your keyboard until you get to a black screen called "Windows Advanced option". (If you don't get to that that screen but you end up reaching the blue screen than that means you have delayed in hitting the F8 key. start again from step 1.)
Step 4: As soon as you reach "Windows Advanced option" use your down arrow keys to choose an option called "Last know good configuration".
Step 5: Select that and HIT ENTER.
Step 6: your PC will boot to the windows.
All the Best
You need to launch the Last know good configuration to get this fixed.
Step 6: you PC will boot to the windows.
rockitman187 and micromend I'll try those on Monday and see what happens. RODGANDYSR I should have mentioned that I had tried safe mode with the same outcome.
