Just need the wiring diagram for a jbl mr-5 stereo to hook up amp and speakers
SOURCE: jbl marine mr-17 all funtions are frozen
Initially, have you tried a full hard reset? The reset button is at the panel at the back of the faceplate, bottom left side. Of course doing so will also erase all presets and user settings & configurations.
Additionally, pls verify that the multiple contacts pins are clean, free of corrosion and makes a positive contact with its mate at the rear of the faceplate. If the unit is used in a salty environment, it may be necessary to manually scrape of whatever blue green build up develops between the connector pins and the plastic insulator. You can try using an old toothbrush and WD40.
Further to check are:
1. the red, yellow and black wire are tightly connected where they are supposed to be connected. If the unit is used onboard, it might be to your advantage to likewise check the grounding system;
2. one of the rear connector is for a remote, pls likewise check that none of the pins are shorting and no presence of any corrosion.
If problem persists, it may be necessary to seek the services of a qualified professional as this involves opening the unit up and tracing the circuitry of the logic/controller circuit.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
SOURCE: won't read the CD's now
have you ever cleaned the lazer lens? goto any CD store and pick up a CD cleaner CD, it is a CD that you place a drop of cleaner on the brushes on the bottom of place it in the CD player and let it play, it will clean the lens that reads the cd, you might have to run it a few times if you have never done this before. that should fix the problem. the CD cleaners are not that expansive, can find them under $20...... hope this helps you..........
SOURCE: I can't find whether or not The JBL MR-17 will
It Does Not. Only standard CDs the manual is here:.http://www.prospecelectronics.com/JBL%20MR17%20manual.pdf
SOURCE: I have a JBL MR-17.2 Sirius Ready stereo
If you have a Sirius satelite receiver box, the Sirius ID number will be on it ir the package it came in. The reciever is seperate form the MR-17.2 and is usually a JBL SIR2.5.
