Changing analog hands / time function due to daylight saving time
What combination of the four buttons which surround the watch do I push and/or hold to reset the hands on my Casio Illuminator Telememo 30 watch please?
To set the Daylight Savings Time on your SKMEI 1163 watch, first press and hold the "MODE" button for approximately three seconds until the "SET" mode appears. Then, press the "MODE" button again until you reach the "DST" mode. Use the "ALARM ON/OFF" button to toggle between "ON" and "OFF" for Daylight Savings Time. Once you have set your desired option, press the "MODE" button again to confirm and exit the setting mode. Your watch should now display the correct time, accounting for Daylight Savings Time.
The digital timepiece on a watch is set using the function buttons on the outer part of the watch face. To set the digital time, press and hold the upper left button until the seconds starts blinking. Press the lower right button to reset the seconds to "00."
Push the lower left button to move to the Daylight Savings Time portion of the watch. Use the lower right button to toggle between "On" and "OFF."
Press the lower left button twice. The hours unit will start blinking. To advance the hour, press the lower right button repeatedly until the correct hour is displayed. If you need to move the hours unit backwards, press the middle right button until the correct hour is displayed. When the hour is set, press the lower left button to switch to minutes, and use the same commands to change the minutes unit.
After the time is set, press the upper left button to exit the digital time setting function.
Setting Analog Time
You may find after setting the digital timepiece that the analog display does not match. When this occurs, you need to set the analog time. To set the analog time, press the lower left button 6 times. Next, press and hold the upper left button until the digital time starts to blink. This indicates that you are in analog time setting mode.
Analog time adjustment is completed using the lower right button. Every time you press the button, the analog time will advance 20 seconds. If you need to make a big change to the analog time, press and hold the lower right button to make the hands move faster. Once the analog time is set, press the upper left button to exit the analog time setting mode.
I have never been able to find instructions on their web site but since most watches operate in a similar manner try the following (some experimenting may be required).
Press the mode button and your watch will cycle through the settings menu. On mine, there is a setting "HS" (hand setting) and then I press one of the other buttons (not the light button) to advance or ****** the hands.
When the setting it correct, press the mode button to reach normal operation.
QUICKSTART - SET THE TIME 1. Push the bottom right hand button until the mode hand indicator points to TME. 2. Press and hold the upper left button for three seconds. The hour and minute hand will retract to the 12 O’clock position. 3. Select the time zone on the digital display by pressing the upper right button or the lower left button. 4. Pull the bottom right button out one click. The bottom part of the digital display will start flashing. Press the bottom left button to adjust for daylight saving time. 5. Press the upper right button. You will see the seconds flashing on the lower half of the digital display. Press the lower left button to reset the seconds to 00. 6. Press the upper right button. You will see the minutes flashing. Press the lower left button to set the minutes to your current time. 7. Press the upper right button. You will see the hours flashing. Press the lower left button to set the hours to your current time. 8. Press the upper right button. You will see 12H or 24H flashing. Press the lower left button to switch between 12 hour and 24 hour. 9. Push the lower right button back in.
SET THE CALENDAR 1. Push the bottom right hand button until the mode hand indicator points to CAL. 2. Press and hold the upper left button for three seconds. The hour and minute hand will retract to the 12 O’clock position. 3. Select the time zone on the digital display by pressing the upper right button or the lower left button. 4. Pull the bottom right button out one click. You will see the month flashing on the digital display. Press the lower left button to change the month. 5. Press the upper right button and the date will begin flashing. Press the lower left button to change the date. 6. Press the upper right button. You will see the year flashing. Press the lower left button to change the year. 7. Push the lower right button back in.
SET THE ALARMS 1. Push the bottom right hand button until the mode hand indicator points to AL1, AL2 or AL3. 2. Press and hold the upper left button for three seconds. The hour and minute hand will retract to the 12 O’clock position. 3. Select the time zone on the digital display by pressing the upper right button or the lower left button. 4. Pull the lower right button out one click. You will see ON or OF flashing on the digital display. Press the lower left button to turn the alarm on or off. 5. Press the upper right button. You will see the hours flashing. Press the lower left button to change the hour. 6. Press the upper right button. You will see the minutes flashing. Press the lower left button to change the minutes. 7. Push the lower right button back in.
SET THE TIMEZONE 1. Setting the time zones allows you to add or remove cities on the digital display or switch between daylight saving and standard time. Begin by pressing the lower right button to move the mode hand indicator to SET mode on the bottom dial. 2. If the hour or minute hands are obscuring the digital display, press and hold the upper left button for three seconds. This will cause the hour and minute hand to retract to the 12 O’clock position. 3. Now pull the lower right button out one click. You will see the digital display flashing. Press the upper left button to select SET to display the city or OFF to not display the city. Press the lower left button to turn summer time on or off. Summer time is indicated on the lower part of the digital display. Daylight savings time must be manually set for each city. 4. Pressing the upper right button will allow you to scroll through all the cities. After setting, push the lower right button back in.
USING THE TIMER 1. Press the lower right button to move the mode hand indicator to TMR mode on the mode dial. 2. If the hour or minute hands are obscuring the digital display, press and hold the upper left button for three seconds. This will cause the hour and minute hand to retract to the 12 O’clock position. 3. Pull the lower right button out one click. You will see the minutes flashing in the digital display. Change the minutes by pressing the lower left button. Once you have set the minutes on the timer, push the lower right button back in. 4. Pressing the upper right button starts and stops the timer. 5. Press the lower left button when the timer is stopped to reset the timer to its initial preset time.
USING THE CHRONOGRAPH 1. To use the chronograph press the lower right button to move the mode indicator hand to CHR mode on the mode dial. 2. Press and hold the upper left button for three seconds. The hour and minute hand will retract to the 12 O’clock position. 3 .To start or stop the chronograph press the upper right button. If you press the lower left button it will display the split time for 10 seconds. 4. When the chronograph is stopped press the lower left button to reset back to zero.
SET THE TIME ZONE 1. Setting the time zones allows you to add or remove cities on the digital display or switch between daylight saving and standard time. Begin by pressing the lower right button to move the mode indicator hand to SET mode on the bottom dial. 2. Press and hold the upper left button for three seconds. The hour and minute hand will retract to the 12 O’clock position. 3. Pull the lower right button out one click. You will see the digital display flashing. Press the upper left button to select SET to display the city or OFF to not display the city. Press the lower left button to turn summer time on or off. Summer time is indicated on the lower part of the digital display. Daylight savings time must be manually set for each city.. 4. Pressing the upper right button will allow you to scroll through all the cities. After setting, Push the lower right button back in one click.
To change from 24 hour to 12 hour, you hold down the "Mode" button until it switches from 24 hour to 12 hour or vice versa. To change the time zone, you hold down the "Set" button until the time zone that you set it in flashes (like "LAX" on my watch). Then you press the "Receive/Start/Stop" button to choose the specified time zone you want. To set for daylight savings time ("DST" on the watch), after holding the "Set" button and having the time zone flash, you could press the "Mode" button. It will give you a few options for the daylight savings time (Auto, On, or Off). I chose the "On" option, which immediately changed for daylight savings time. If you manually want to change the time, you could hold down the "Set" button and keep pressing the "Mode" button until the time starts flashing on your watch, then pressing the "Receive/Start/Stop" button until you change it to the time that you want. You could also set the watch to beep or chime after pressing the set button if you wanted to know that piece. You hold down the "Set" button when you are done to get it to stop flashing. These instructions worked for my Timex T5G341 Universal Radio Control Watch. I hope this helps.
Sometimes a watch will be off center due to shock, dead battery etc. Symptoms are; hands don’t line up, digital and analog time doesn’t match, Compass function doesn’t have the hands exactly opposite etc. This can all be fixed. The Synchronization function can be used: 1. Activate Crystal 2. Tap center until you are the unit’s screen (12h or 24h, F ft or C m). 3. Push and hold (at least five seconds) the center crown 4. Watch will beep and word (SYNCHRO) will appear in the display. 5. Use the top + button to line up the minute hand right on the 12. 6. Use the bottom – button to line up the hour hand right on the 12. 7. When finished, press crown and you will go back to time.
If yours is like mine, there are four buttons on the watch. These are at 10, 2, 4 and 8 o'clock. Hit the 8 o'clock 6 times. You get a digital readout of time and the letters HS. Then press and hold the 10 o'clock until it flashes. Then use the 2 and 4 o'clock buttons to advance or ****** the analog hands. Hold them for fast advance/******. Momentary push for fine adjustment.
Use this page to download a copy of CASIO watch manuals in PDF format. To download a PDF file, enter the four-digit (or three-digit) module number marked on the back cover of your watch.
